Money pits
Results 1 to 4 of 4
Thread: Money pits
    759
    Money pits
    1979 Cherokee chief
    black and grey original interior
    with a 4bta cummins under the hood. motor is turned up putting down 201hp/ 487 ft/lbs at the rear wheels with no EGT problems. NV4500/D300 with dodge 13" flywheel and clutch.
    averages 24-26 mpg on the highway, has 3.54 gears with Ploks front and rear a nd a scout 33 gallon rear tank. And oh yeah...... AC works.
    The other money pit CJ7
    401 T18 D300 lo max 4:1 kit w/ F&R 32 spline outputs
    current engine:
    401 std bore lots o miles
    stock compression
    222/222 dur@.050 292/292 adv dur .479/.479 114 lobe sep
    1974 stud heads
    twisted manifold (torquer)
    670 TBI howell fuel injection system
    non-smogger manifolds port matched and married up to Dual 2.5" exhaust
    ARP bolts all around
    Waggy D44 front CTM's and Warn shafts 4.56 with ARB
    Scout D44 Rear Alloy USA shafts 4.56 with ARB
    35" tires
    Motor in the works
    401 .030 over speed pro 9.8:1 pistons
    bridge heads ported, studded and guideplates installed
    performer intake
    Lunati cam:
    Advertised Duration (Int/Exh): 256/262
    Duration @ .050 (Int/Exh): 213/220
    Gross Valve Lift (Int/Exh): .484/.507
    112 lobe sep
    Member #377
    Living in reality can work if your realistic
    10,046
    Quicksilver!
    Featuring
    www.Plasmaland.com for CNC plasma machines
    Feb 2005
    East Bethel Mn
    1,260
    Kick azz rides. I really like the cherokee with the cummins in it that had to be a lot of work.
    VOTEBUTTON
    759
    Quote Originally Posted by BREK
    a little bit took a couple of months... but we were in the process of buying a house and moving at that time soooo numerous delays. now i drive it daily.
    25 mpgs baby
    thanks guess you could call it quicksilver i think the sick 401 under the hood might cause it to be called sicksilver till i get the new motor in there
    Member #377
