Results 1 to 3 of 3
Thread: CAM TIMING USING A COMPRESSION GUAGE
    Mar 2008
    connecticut manic mechanic
    105
    ANYONE USE A COMPRESSION GUAGE TO MEASURE MAX CRANKING COMPRESSION WHILE ADVANCING OR RETARDING CAM TIMING, ANY INPUT ON THIS ? I AM LOOKIN FOR MAX LOWER END TORQUE USING SUMMITS K8600 CAM
    an amc was my first car and so will also be my last car/jeep
    Nov 2005
    Middle of the Iron Range MN
    1,229
    I think the concensus is that advancing the cam moves the power band down and retarding it moves it up in the rpm scale
    Mar 2008
    105
    thanks
    thanks
