Helpfull BT forum member
Junior wrench of the Forum
AMC 401 TF-727
How much can I get for this set up or what is a fair price? It is currently in the Jeep.
Rebuilt 727 mated to below 401.
Motor Details:
1974 AMC 401
Completely rebuilt
8.5:1 Cast pistons .030 over
Federal Mogul rings & engine bearings
Comp Magnum Cam 270/270 Duration, .480/.480 Lift
Comp Lifters, retainers, and springs
Melling timing components
ARP Head Bolts
New harmonic balancer
Main bearing & timing chain oil kit/modification (re-directs oil to known problem areas of AMC motors)
Offroad MSD Ignition System w/ Rev limiter
MSD 6 Offroad Ignition
MSD Rev limiter (6000 RPM chip)
MSD Blaster high vibration coil
MSD Pro Billet Distributor
Holley Truck Avenger 670 carb with K&N air filter
Edlebrock RPM Air Gap Intake Manifold
Dual exhaust with Flowmaster Hushpower mufflers
New flywheel & ring gear
- You may not post replies
- You may not edit your posts
Forum Rules
