I am running out of ideas.... I have a t-18a tranny that I believe is a FORD ( 1 1/16 dia. 10 spline short shaft, with reverse up and over next to 3rd. ). I no longer have an id. tag on this tranny. Attached to the t-18a is a DANA 20 with the id. tag still attached.
Only markings stamped into the top of the case are B255 2.
All of this was transplanted into my 1978 cj-7 along with a 360 motor. I know that at some time the tranny and transfer were seperated because of the types of sealants used for gaskets.
I am trying to find out which of the year(s) this tranny was used. The dealers are no help (they want the vehicle info), tranny shops have not been much help either. Am I screwed without the id. tag? Can the casting numbers be traced?
I do know;
1967-1978 reverse was "over and up"
I am using a 1976-1979 style clutch disc
1972 and laterused a 6 5/8 bell housing
Since I am rebuilding both cases is there any way to ID the internal parts? Thanks in advance for any thoughts on the matter.
