ok so i have a 1971 amc javelin in drag trim with a amc 401 bord .30 over port and polished heads ( 51 cc) with mopar 440 valves harlen sharp roller rocks with girldel. the bottem end is stock minus the forged pistions ( stock style piston tho) shot peend rods and what not. it also has a external dual line oil pump along with under the intake oil mod and the dist gear oil mod. Cam is a comp cam custom grind with specs
292 in 292 ex duration
596 in 596 ex lift
110 lobe separation
solid flat tappet
just so you kinda get a feel for my motor
so this last season i kept going threw cam and dist gears so bad that it wrecked my timing cover and oil pump gears. along with a couple rear bearings so will the bull tear cam and dist gear set fix that? and my car also had a cam walk plate should i be taking that out?
along thing i am kinda woundering about is how that bull tear alt bracket works dose anyone have a picture of it installed please?
I will post some pics up when i get home
thanks justin
