AMC V8 Serpentine system with AC support - Page 5
Page 5 of 5 FirstFirst ... 345
Results 41 to 47 of 47
Thread: AMC V8 Serpentine system with AC support
  1. #41
    Living in reality can work if your realistic
    10,046
    No I cannot. I don't have any access to those items until we reopen on Monday.
    Featuring
    www.Plasmaland.com for CNC plasma machines
  2. #42
    Jun 2004
    7
    Thanks. Can I just order the 3 bolts and required spacers? They were not included in my kit so I reused the stock bolts hence the misalignment vs. the other pulleys.
    The more I practice, the luckier I get
  3. #43
    Jun 2004
    7
    Quote Originally Posted by cw05 View Post
    I never got a response to my phone message or emails so I made some shims myself yesterday. It is close but still ~1/8" off. I cannot shim the York bracket further without disrupting the alternator bracket since they share a common bolt through the water pump. Any suggestions?
    Also, the Gates belt (K061031) you recommended is incorrect. Do you know what belt is correct for this system?
  4. #44
    Sep 2016
    Slovenia
    1
    Hi I have a 70 AMX and putting my setup together and what Power steering pump do i need and a Alternator a part # would fantastic!!! and a routing lay out for the belt with no Ac and Alternator on the bottom?
  5. #45
    Nov 2017
    USA
    1
    Second this
    Quote Originally Posted by Cybermoose View Post
    I second this. I have most pieces to add to my 69 AMX, but missing the P/S pulley, and I have the lower alternator bracket. Please let me know what parts I need to complete, and a routing for the belt.
    I have:
    Alternator Pulley
    Lower Alternator Bracket
    Crank Pulley
    Water Pump Pulley
    Need
    Power Steering Pulley?
    Idler?
    Tension arm?
    Help please, new to this forum, but not AMC
  6. #46
    Dec 2018
    Guam
    1
    I just bought this kit from a freind of mine that passed away. I am putting it on a 73 401 with PS and A/C (York). I am having a really hard time getting everything to line up.
    1) Are there different crank pulleys? My crank pulley sticks out, the most, BY FAR. They were is probably a good inch to an inch and a half difference between my crank and the A/C compressor.
    2) I can get the crank and water pump to line up with about 1/2" worth of spacers. Is this normal?
    3) How do I adjust the power steering pump in and out?
  7. #47
    10,046
    First you need to know what you have. The Crankshaft harmonic balancer must be pressed in all the way first. That will set all the other pulleys. If you water pump is off .4375 or 7/16" inch then you have the wrong year water pump or your kit was ordered with the wrong pulley (We make both styles). Next the AC pump should have spacers to bring it out so the pulley lines up with the crank.
    Featuring
