360 exhaust routing with stock linkage
Results 1 to 3 of 3
Thread: 360 exhaust routing with stock linkage
    Mar 2008
    canada
    114
    Hi,
    I've red a lot on the stock 360 driver manifold and the stock clutch linkage. It seem like a 304 manifold will clear the linkage or Hydro clutch systeme would be the other solution.
    but did any of you had luck with the stock manifold and custom exhaust systeme... I'm planing on a 2.5" out and 3" single to the back.
    pics would help
    thank you
    That rear dump drivers side manifold was never used on a CJ (or a Wagoneer w/manual trans for that matter). I doubt you'll find enough clearance to use it.
    All the exhaust manifolds are 2 1/4" at the dump. My CJ uses 2 1/4" pipe for each side, then 3" from where they meet to the rear. I run the CJ driver side manifold that dumps on #5.
    Mar 2008
    canada
    114
    ok I guess I'll try to find a CJ 304 driver side then and do like you did tufcj sounds like a good way to do it.
