Results 1 to 6 of 6
Thread: Dana 44 brake/hub assembly question
    Mar 2008
    North Plains, Orygun
    132
    I have a Scout front D44 with disc brakes. I have it all disasembled and stupid me, I can't remember the way I took it apart. Does it go spindle, caliper mounting plate and then dust sheild or caliper plate, spindle then dust sheild. I spent the last hour or so trying to find a picture or diagrahm and have found both ways. Anybody know for sure? Is a Scout different then other 44's?
    HELP!
    74 CJ5, 360w/T-18/D20, Scout D44's Locked front & rear w 5.38's, 36" Swampers & a ton of work...
    It's a Jeep thing, Chrysler doesn't understand!
    Feb 2007
    Minnesnowta
    151
    iirc, spindle, caliper bracket, dust shield. There should be a machined ring on the knuckle side of the spindle that snugly fits into the hole in the knuckle. You should also be able to see which part the washers were against.
    To verify, put your hub back on and check caliper fitment.
    -Abraham Lincoln
    Agreed. Spindle, caliper bracket, dust shield. Same as the 76-79 CJ dana 30 with "big brakes".
    Mar 2008
    132
    That's what I thought, I'm just making sure. It was late last night and I thought it would go on both ways. It just didn't seem right with the caliper bracket first.
    Thanks!
    Mar 2008
    132
    Are the dust covers that important? They're all bent to crap. I took them off my D30 and never had a problem.
    Not a big deal. I ran without them on my Dana 30. The brakes may just not be as effective on wet roads due to splash.
