ok i have a question maybe someone might know. im thinking of purchasing the platemarker from torchmate seeing how it is on sale till the 31st. now will the bladerunner controller be able to run it. i know sheetcam has tooling changes that can support it but not sure if the controller can
Just got off the phone with torchmate tech support. They said the plate marker on their system works off of a signal generator that activates the plate marker on and off. They said as long as you have a relay in the controller that pulses signals it will work. And also a supply of 110 voltage.
I believe the manual said the controller can support 110v as long as u supply the 110. I'm I correct on that. And if my machine his running 4 motors I have an extra spot for the 5th axis which would signal the plate marker.
Your controller should be able to support 2 extra outputs and the 110 power. You will need to contact Tom @ Candcnc for info on this we currently dont offer any details on adding an air engraver but are looking into making one for the tables and gantry kits.
when will you have one avalible. i am very interested in one. i talked to tom he said it will work. torchmate said it should work but they are not sure how the interface would work. sheetcam has the option for extra tools so it should work.
once again i am very interested in one. if you can get one going in the next few weeks i would gladly buy one. im am sure their are others with the bulltear machine that would to
thank you very much. id rather buy from you then torchmate, but not your problem, i have some jobs coming up that i need to engrave so the sooner the better...
Jan 2010
Australia
8
as i have already asked you i would also be very interested.
It is many many times cheaper to usean electric engraver and a saddle for it than to use the air engraver. If you ask around they both wear out. Someone told me the air engraver kit was going for over $2K!
