Results 1 to 7 of 7
Thread: roller rockers
    Jul 2007
    8
    roller rockers
    I purchased a set of Scorpion bridged roller rockers for my 401 (3220502 heads) fitted with new Compcam lifters. Of course when I went to use my original 7.794" AMC pushrods, they were a 1/2" inch short. I made up a custom adjustable pushrod to determine the new rod length. I'm getting 8.250" which gives just slightly over a 1/2 turn of lifter preload. Has anyone installed non-adjustable Scorpion rockers and what pushrod length are you using?
    I moved this from the customer service forum.
    Can't help you on the non-adjustable rockers. +.100 seems the norm for any adjustable, although every installation is different due to factory machining, valves, valve seat, head milling, block decking, etc. Just too many variables for a 1-size-fits-all.
    Oct 2006
    Virginia
    771
    X2
    Nov 2005
    Middle of the Iron Range MN
    1,229
    do these require the rocker bosses to be machined for them to work right?
    Jul 2007
    8
    No, they fit and bolt on nicely with the right geometry, just need longer pushrods. I have a picture of the engine 250kbs but can't figure out how to post it. Oh, by the way, you can't use your original valve covers, too low. You need approximately 3/8" more inner height.
    You need to use a photo hosting site like Photobucket (free) to post pics.
    To change from bridged to individual rockers, they generally mill about .375" from pedestal, so .500" really doesn't sound that far off with no machining. If you still have the manifold off, the plunger in a hydraulic lifter should be compressed about .020" below the retaining clip.
    Jul 2005
    S.W. WA
    692
    Doesn't sound outrageous to me. On the 360 I built years ago, I think I used 8.20" pushrods, and that was with adjustable rockers.
    1969 Rebel 401 TH400
    1978 J10 401, QT
    1978 Wag 401 QT
    1973 Javelin AMX in pieces.
