Results 1 to 5 of 5
Thread: 700r4 durability???
    Mar 2005
    MN
    307
    700r4 durability???
    Well, I happened along a '87 700r4 transmission for $50 and bought it. After searching alittle I am thinking it isn't as strong as the th400. Have any of you guys had first hand experience with the 700r4 behind 500hp in a heavy truck?
    High power and high weight? It probably won't survive long in stock form. Take it to a trans shop and have HD parts (drum with more planetaries, HD clutches, and shift kit) put in it, along with a large cooler, and it will survive quite well.
    I had one in my Suburban (with upgrades), only about 300 HP, but pulled a 7000 LB trailer thousands of miles, and never had a problem.
    Nov 2005
    Middle of the Iron Range MN
    1,229
    If im thinking right it's the precursor to the 4L60/4L60E tranny under 1/2 tons today. I thought they liked to run warm but could be made pretty strong with the right parts but still not near as tough as the th400/4L80
    Mar 2005
    MN
    307
    Does anyone make and adaptor plate to run the 4L80E with A AMC V8 and a NP205 transfer case?
    Try Advanced Adaptors http://www.advanceadapters.com/ or Novak Engineering http://www.novak-adapt.com/
