Locker Advice
Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Thread: Locker Advice
    Mar 2008
    North Plains, Orygun
    132
    Locker Advice
    Some background~
    I recently put D44's in both ends of my CJ. The axles I bought had welded spiders in the rear and open in the front. I took the Powertrax No-Slip I had in the rear of my old axle and put it in the new front end leaving the rear welded. On my recent trip to the dunes, the rear carrier broke in half.
    I've had the No-Slip for 6+ years in the rear end and have been very pleased with it, good off road and decent street manners. So my question is would it be good to buy a second No-Slip and run one in both ends? I would love a selectable, but it's not in the budget. My wife gave me $500 smackeroos last night! Love that girl!
    So, any advice?
    74 CJ5, 360w/T-18/D20, Scout D44's Locked front & rear w 5.38's, 36" Swampers & a ton of work...
    It's a Jeep thing, Chrysler doesn't understand!
    Feb 2007
    DC suburbs
    333
    Can't go wrong with a good ol' Detroit.
    Mar 2008
    132
    Do the Detroit's "unlock" one wheel while turning? My No-slip will as long as it's not under a load, throttle. I see they are on the high side of my allowance, over $500.
    759
    Id go Pwoer Lok LSD or Air locker. I used to be a die hard detroit fan, "they never break and always work" what i have found is in off camber or tight turns that my detroit used to really push me and in situations where i had a tire up in the air the rear would ratchet every once in awhile and shock the tires causing me to slide off the line i was attempting. Point is my current setup is Air lockers F & R and the improved ability to control traction and keep things even more predictable than my detroit has been priceless. My Power lok was more predictable than that darned detroit withs its ratchet pop suprises at in-opportune times
    So much so that I will not go back to a detroit for an extra $160 i upgraded from my broken (yes it broke) Detroit to an ARB and I am tickled.
    I have four buddys that all have Early broncos, one with ARBs F&R like myself and three with detroits in the rear two just built high dollar HI-9 rear ends with 35 spline shafts they all have ARBs in front already they both used detroits again and after our recent trip to the rubicon (thier maiden voyages) they all three vented that they wished when they built thier rear ends they would have spent the extra couple hundred bucks for the selectability, they found on indian slabs the off camber combined with tight turns resulted in more than $200 worth of paint being scraped off on a Rock. All walked the exact same line, pretty much the only line they could take, all are good drivers but all found the wet granite combined with loose dirt and the locked up detroit over powering the steering of the front end made things mroe difficult than it was for the Rigs with F locked and rear end unlocked at that particular spot. food for though i have 9 years on my ARBs and never a single failure D44's F&R with alloy shafts F&R
    Save money, trade in beer cans, sell your spare tire .... pay now or complain later. this sport is one of compromises but i find my diffs to be one spot where compromise usually equates to a higher price paid later.
    maybe install a cheap Power Lok or open diff that you weld up for now and then save the pennies for what "you'd really like" there was a used ARB on pirate for $450 the other day.
    Don't get me wrong detroit will do the job i just think there are gentler, more refined and definately more predictable devices out there
    Member #377
    I've got Dana 44s in both ends of my CJ. I'm running the old style Detroit in the front, one of the newer soft lockers in the rear. They're always there when you need them, and you don't have to think about them.
    I haven't experienced the ratchet problem that Dusty described, but having a twin stick dana 300 so I can run 4-LO really helps the turning radius.
    Mar 2008
    132
    So should I drink more beer to save my cans for an ARB?
    I'm really on the fence... I keep seeing used ARB's on Craigslist for decent prices, I'm just worried about buying a used locker. I'm in no hurry to buy a locker, I have a spare carrier and gears I'm going to throw in so I can drive it for now.
    If I was to buy a used ARB, what other things do I need besides a compressor?
    The big thing with an ARB is the bearing on the pressure side, if the O-ring in it is damaged in any way it won't stay locked. It's a special bearing from ARB, and fairly pricey. Remember the bulkhead fittings and lines.
    Mar 2008
    132
    What about Ox Lockers? They are close in price to ARB's, maybe less if you buy the compressor.
    I haven't heard anything but good about the OX lockers. Pretty much like an ARB, but cable actuated. Part of the price is that nifty billet cover.
    Another thing to consider, used ring and pinions were set up and have stresses based on that first configuration. Reusing a R&P is not a good idea. Using a used 'locker' may have similar consequenses.
    Quote Originally Posted by northplainsdrifter
