Results 1 to 9 of 9
Thread: 4 Bolt Caps
    Oct 2006
    Virginia
    771
    4 Bolt Caps
    Does anybody make 4 bolt main caps?
    2,840
    Pro-Gram Engineering. http://www.pro-gram.com/
    I believe it's a 401 mod, as the main webs are thinner on the 304/360 blocks and don't have enough meat to drill bolt holes.
    Remember that the block will also have to be line bored after installing the caps.
    Oct 2006
    Virginia
    771
    Hmmm, I thought that there were thicker casted 360 blocks that would support this mod?
    Yup, sure do... Standard practice.
    Jun 2005
    CT
    608
    Quote Originally Posted by fifesjeep
    Yep but those blocks are very hard to come by, I think they were cast for Trans Am racing.
    Oct 2006
    Virginia
    771
    Quote Originally Posted by Blown7
    Cool, makes sense. I'd be nice to stumble upon one in good shape.
    Sep 2006
    35
    360 block
    Quote Originally Posted by fifesjeep View Post
    Yes they were used in Trans Am but some of the later service replacement 360's came with the thicker webbing. I remember seeing one in a 74 Javelin that had a factory motor repalced in the mid 80's and it had the thick webs. Only one I ever saw
    Jan 2013
    Argentina
    1
    The one at 74 Javelin was good enough. I still wonder why they did not make more in any of those ever.
    Everyone, take one... repo trucks for sale
    Nov 2005
    Middle of the Iron Range MN
    1,229
    The factory service blocks were basically a blank with slightly heavier castings, it was up to the final user what they were at the machine shop (304/360) IIRC
    Sep 2014
    Ecuador
    4
    My first post here. AMC 1970 390 and all 401's will accommodate 4-bolt mains. The "service block" is as described above. It has the same bottom end as the late 390 and all year 401 and was a 4.08" bore 360 cylinders with enough material in the cylinder bores for the service department to bore to 4.165" 390 / 401 specs if required. There were some smaller 290 engine blocks made with 4-bolt provisions but that was a Trans-Am race block and very rare indeed.
    Milidon and Pro-Gram Engineering make excellent 4-bolt main caps. Milidon availability can be iffy, Pro-Gram will get them to you in a reasonable amount of time. You can buy the three middle caps with 4-bolt. Pro-Gram also offers billet #1 & #5 caps but those are 2-bolt. Just keeps the billet theme going. I have all 5 on my '70 390 race engine. You will need to line bore / hone ANY block if you change the caps (even if factory standard caps). Caps are married to the bore.
