Results 1 to 2 of 2
Thread: T10S ID?
    Aug 2010
    Woodbury Heights, New Jersey
    0
    T10S ID?
    I have a T10 Trans in my AMX with markings on the tail housing T10P-7A and T10P-1B on the case. The tag reads AS8-T10S, any ideas what this was originally in? Also there are no grooves on the input shaft.
    Also has a build date of 1972......funny nobody in any forum has helped me......strange.
    Oct 2006
    Tn
    302
    I looked at the one for my 70 AMX and apparently the T10P-7A and the T10P-1B are Part Casting Numbers for "W.G. Div"....Warner Gear Division also cast in mine are the same.
    My tail shaft it date coded H-25-69 and my case is 1/27/70.
    I can only assume that AMC started out with an A for for January. That would jive with the build dat on the case being Jan. and the cars production date.
    Tags been broke off before I got it but I know it's the original for the car.
    Hope this helps.
    Jerry
    48 CJ2a 283
    62 Dodge Panel Truck 3 on tree
    62 Belvedere Max Wedge Stick
    65 Dodge880 383 auto
    64 Jeep DJ3a 2wd
    69 CJ5a V6
    2 CJ6a's V6's 1 T98 4spd
    80 Scout Terra SD33t Nissan Turbo Diesel T19
    83 J20 360 T18
    70 AMX 390 Go Pac 4spd
    70 AMX 390 Go Pac Auto
