Did a fuel pump on a friends '03 Silverado a while back. The tank was full, so it was actually easier to remove the bed than drop the tank.
True, but I have had this fix a ford with a plastic intake, and a former coworker fixed a 6.0 chev just like yours, same issue.Originally Posted by ironman_gq
parting several FSJ'S
I've done quite a few pulling the bed, 8 bolts, if it has an aftermarket hitch that may cover the 4 rear bolt acess holes in the frame.Originally Posted by tufcj
With 38 PSI I would start there also and see if that does it.
Definately plan on pulling the bed off. I really dont want to try and drop the tank on my garage floor, If I had a lift it would be different but I dont (is on my list for the future, they are fairly inexpensive for what they can do)
