-Abraham Lincoln
-Abraham Lincoln
-Abraham Lincoln
Masalba wrote:
No changes were made to the ignition switch or wiring (intentionally).
I believe the key to my problem lies in the fact that I have no power to the relay after the key returns to the "RUN' position. Why that is I cannot figure out yet.
Your problem does not lie in the fact that you have no power to the relay after the key returns to the "RUN" position." It is NOT supposed to have constant power. Your relay is a momentary contact relay. Meaning that it only works while the key is turned to start.
I just checked my Key Sw. which has 4 terminals: Batt, ign, acc, and st., all marked on the key switch. Yours will have these markings too. The st. term. is for the start switch relay ; your momentary cont actor which will only have power as long as the key is held to start. The ign. is the run position which you should have a wire running from there to your coil. The Batt. is the power supply from your batt. through your fuse panel. The acc. is for the radio, fan, ect.
By the way I am a retired electrician.
Larry The Old Rugged Crosser
Thanks for all the help guys...after tracing the "other" red wire back from the coil and thru the fire wall I was able to find a modular connection that had come apart in mid-wire. Problem solved.
Now one issue down and several hurdles left, but the engine is running properly and we are dialing in the carb.
Both Msalaba and ORC were right on the money. 500 bonus points are awarded to you both for this round. Thanks.
I got 500 Bonus points!
Glad your problem was sovled
-Abraham Lincoln
