Warning: preg_replace(): The /e modifier is deprecated, use preg_replace_callback instead in ..../includes/class_bbcode.php on line 2968 OIl pump mid plate question
Are there two different gasket designs when using a oil pump mid plate or do you use two normal oil pump gaskets on either side of it? It looks like it should have a different design/cutout gasket between the plate and oil filter adapter. Mine came with three gaskets of all the same design. Thanks for any help.
