Hi everyone, What are the torque specs on the 1/4 inch bolts for the oil pump/oil filter adapter? Thank you.
I've never torqued mine, just make sure they're tight but not over tight.
I looked in the TSM and couldn't find a torque listed.
According to this table: http://www.engineershandbook.com/Tables/torque.htm
Torque spec on a grade 5, 1/4-20 bolt is 10 ft lbs. Since it's threaded into aluminum, I'd go a little less.
