Engine Block Heaters & Battery Blankets
Results 1 to 5 of 5
Thread: Engine Block Heaters & Battery Blankets
    Sep 2003
    1,155
    Here is what I just found but its NOT for a CJ :(
    OK guys time to order :)
    http://www.autotrucktoys.com/jeep/Mo...-PRD20931.aspx
    Write up:
    http://www.jeepforum.com/forum/f9/en...install-928591
    Post 12 will give you a idea/picture.
    http://www.jeepforum.com/forum/f96/a...stalled-933951
    http://www.fordtractorpart.com/tract...s-270-ctg.html
    Battery and Pad Heaters:
    http://www.padheaters.com/battery_heater.html
    http://www.jcwhitney.com/blanket-sty...23&zmap=541427
    Mudrat sent me this:
    Sorry don't have a source for block heaters. JC Whitney is showing a couple oil pan heaters though ...
    http://www.jcwhitney.com/oil-pan-hea...lterid=c1648j1
    http://www.jcwhitney.com/magnet-moun...lterid=c1648j1
    And Titan offers some size/capacity options:
    84' CJ8-360-Project M170 Jeep
    86' CJ7-258-Mommas Jeep
    Sep 2003
    1,155
    Does anyone know the size of the freeze plug for a 1986 AMC 258 and for a 1977 (I think) AMC 360?
    I am also going to check into the lower rad hose install, from what I hear it is easier and works the same.
    I have a magnetic one like this some one gave me, haven't tried it yet but from what I hear, they don't work so good:
    http://www.jcwhitney.com/magnet-moun...65&zmap=10836G
    NAPA: 258 CID ('86)
    http://www.napaonline.com/Search/Res...99&Ntk=Keyword
    NAPA: 360 CID '78
    http://www.napaonline.com/Search/Res...+50038+2038032
    Lower radiator hose, same link as above for the 360:
    Last edited by rollbar; 11-26-2010 at 06:52 PM. Reason: To list more options. Maybe MC might want to move this to the "Engines" section.
    Sep 2003
    1,155
    Question, which is better, the block or the hose installation?
    Sep 2003
    1,155
    Starting at post 57, I installed the engine block heater, w/pics etc.
    Post from my CJ8 Build
    http://www.bulltear.com/forums/showt...803#post129803
    Sep 2003
    1,155
    Hey, what's this hole for, MFG the block?
    I see I have some touch up to do.
