Results 1 to 2 of 2
Thread: A/C Accumulator??
    Jan 2011
    Thesss
    3
    A/C Accumulator??
    So, I post a week or two ago about leaking AC (got a slow leak, lasts a few weeks before recharge). I decided to go the environmentally friendly route and have it checked out one more time. I take it to the local AC guy. He keeps it most of the day, calls me and says compressor is leaking. Can fix it for $850!!!!! So, after I stop laughing, I pick the car up (at least the guy didn’t charge me anything for the testing), and tell him no-can-do.
    Do I need to take my car somewhere and have the system de-pressurized or can I just crack it open? The guy quoted a new A/C accumulator also. He said once you break open the system, you must replace the accumulator. Is that true and if so why?
    many thanks.
    If the compressor is leaking, the freon is probably gone. If you're going to the expense of fixing it, the accumulator, receiver/dryer, and leaking compressor should all be replaced. Look into having it upgraded to R-134. You'll then need to have the system evacuated (air and moisture purged) before you can put the new refrigerant and lube in.
    His estimate is a little on the high side, but not ridiculous considering the parts you need.
