6cyl V8 Forged pistons
Results 1 to 7 of 7
Thread: 6cyl V8 Forged pistons
    Thumbs up 6cyl V8 Forged pistons
    Available in 4032 and 2618 alloy these pistons are top notch. We can machine them for virtually any pin size, any compression height and any compression or ring package. Here we are showing the 6cylinder pistons. These pistons are available in bores 3.875-4.300. They come with accumulator grooves and are cut for wire locks with wire locks are included at no extra charge. (press fit do not require installation of the locks)
    compression heights from 1.17-2.00. Dish volumes from 0cc-34cc.
    Shown here with
    3905 diameter
    1.380 CH
    .930 pin diameter
    5/64 5/64 3/16 ring grooves
    28CC dish
    Mar 2011
    Spain
    7
    Hello.
    I am interested in a set of pistons for my jeep Stroker.
    I need dish approxmately 32-34 cc, (C. R. about 8.65 to 1).
    How do I order?
    what data are needed?
    Thanks.
    Order using our online E-store and put your needs in the notes while ordering. Their is no extra charge for changes.
    Mar 2011
    Spain
    7
    Hello.
    The current pistons are mounted on the motor (I know they are 0.040 oversize).
    I need to get to take some information?
    How much is sipping to Spain?
    What is te approximate delivery time?
    Thanks.
    When you order custom pistons you need the following information
    1. Bore size
    2. Compression wanted
    These are optional infos that we may ask from you
    1. Has the deck height been modified or lowered?
    2. Casting head number or combustion chamber volume
    3. Stock press fit or aftermaret floating rods?
    4. Stock width rings or other
    All pistons at least 3 week lead time 5 week max if ordered in the next 2 weeks. Shipping to Spain cannot be quoted right now because of fluctuating gas prices we no longer hold shipping quotes and will give you a solid number when they are ready to ship. Close to the $120 range for shipping I am sure.
    Mar 2011
    Spain
    7
    Ok, so I have wait for the mechanic remove the pieces and measured.
    Thanks.
    Mar 2011
    Spain
    7
    Hi, the mechanic has not remove the pistons, but I have decided to place an order, with the following information:
    Bore 3.197"
    I want about 8.6 CR
    Current Deck clearance is about 0.025"
    Casting head number is 0630 (I have measured about 58 cc)
    I want pistons dish volume 34 cc
    I want rings similar to stock (+0.040)
    I wan zero Deck Clearance
    Is this enough?
    Do the pistons come with rings?
    How do I pay for shipping?
    Thanks
