Results 1 to 4 of 4
Thread: bw1339 fluid
    Jan 2008
    Sweden
    2
    bw1339 fluid
    Hi !
    I have a Cherokee Chief -79.
    I insalled a new chain but my break cones was not in the best chape... but okey.
    Now...must i have the TCL-1 fluid in my transfercase or can i use automatic oil like Dextron?
    I have read about non-detergent 30w oil....but i canīt find it whitout "detergent"
    I live in Sweden and there is almost nothing new parts to bye here...especially no oil.....
    And ofcourse.....i am in a hurry !!!!
    Forgive my English writing ;)
    //Magnus
    Jan 2003
    s.e. minnesota
    1,351
    It has to be TCL-1 or the 30wt not detergent, with limited slip lube added, only way you can run ATF in one is if it had a part time conversion.
    parting several FSJ'S
    Jan 2008
    Sweden
    2
    I have one bottle of TCL-1 for the low-range unit.
    Can i use 30w with detergent in the transfer case?
    Bulltear forum member Cook
    Jul 2004
    Jubilee Jeeps
    21
    macfsj, if you are still around - NO. The low range and main QT case share fluid and it is all TCL1 or equivalent you want. In case you have not found it yet, there is a good site for QT info including PDF file of the QT TSM.
    http://jubileejeeps.org/quadratrac
