Jeep won't stay running (ignition maybe) - Page 3
Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 36
Thread: Jeep won't stay running (ignition maybe)
  1. #21
    Apr 2010
    Bothell Washington
    228
    Jim honestly, that is the worst rats nest of wiring I have ever seen and I have seen some bad ones. You are better off to strip it all out and start over. It is really not that hard to re-wire. It would be much easier to do that than to fight that mess. Just think what a mess it would be to break down on the trail and have to deal with that. I could probably give you instruction on the re-wire.
    Just leave all wires running through the firewall. Detach all wires out front and take off all that plastic wire protection. Do not cut anything coming through the firewall.
    Larry The Old Rugged Crosser
  2. #22
    I'm really lost when it comes to wiring. I would suggest picking up a Haynes or Chiltons manual that has wiring schematics in it before chopping the whole thing out.
    There is a guy on ebay who sells ones that are in color matching the wires.
  3. #23
    Oct 2006
    Virginia
    771
    I actually have the fold out wiring diagrams... I can snap some pics and upload them if that would help you.
  4. #24
    Sep 2003
    1,155
    Larry,that is a old pic when I first laid out the harness. I will take a pic of the compartment.
    I would like to go to bare minimum but like Bob.........
    84' CJ8-360-Project M170 Jeep
    86' CJ7-258-Mommas Jeep
  5. #25
    Sep 2003
    1,155
    FIXed IT!
    Checked the switch re/red white/blue = all work.
    Then at the fire wall inside the Jeep I have power except to the red/white wire, looked at the TAC lead, hooked it up and the rest is history.
    I never hooked up/plugged in the TAC lead under the dash !!!!!!!!!!!!!!!!!!!
    Runs perfect.
    Sorry to run you all around for something stupid like a connector but I guess we all learned something from this thread.
    I will post pics later.
    Thank you so much,
    P.S. Going back out to fiddle w/it, I'll check back later.
  6. #26
    Sep 2003
    1,155
    Ok, here is the video.
    Oil Pressure:
    60psi = cold
    45psi = warm
    24psi = hot
    Still have to get the temp gauge & fuel gauge working.
    Thank you all for your help.
    My U-Tube video of her fired up:
    http://www.youtube.com/watch?v=tQd0r7BnTHM
  7. #27
    Sep 2003
    1,155
    Under dash pics:
    Here is where the TAC was not hooked up:
    Under dash pics:
    Oops, I see I missed a sopt w/the U-POL Raptor
    Engine compartment pics:
  8. #28
    Apr 2010
    Bothell Washington
    228
    Quote Originally Posted by rollbar View Post
    Under dash pics:
    [/QUOTE]
    Jim,
    I still can't feature why you need so much wiring. I am running the same motor as you are and I don't have that much wiring.
    Here is some pic's of my engine compartment:
    Mine is complete and will add nothing to it. How come so much difference?
  9. #29
    Sep 2003
    1,155
    Larry, I used the I-6 harness and have yet to clean it up. not sure exactly how but I guess I can start at the ECM plug and work my way up the harness.
    At least she runs :)
  10. #30
    Feb 2007
    Minnesnowta
    151
    For Future Reference:
    The most confusing part of a Jeep ignition system is the solenoid connections. The blue wire is the "start" position +12vdc. It both actuates the starter solenoid and sends a signal to the Duraspark module. The red/white coming off the solenoid supplies a full +12vdc to the coil while cranking. It serves no other function. The purpose was to bypass the resistor wire while cranking for an easier start. All other ignition power is supplied through the ignition switch. (Kinda like burning your candle at both ends)
    Here is a schematic for illustration:
    -Abraham Lincoln
