Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Motor Problems, help!
  1. #11
    Nov 2009
    Abq, NM
    47
    I did check the set screw on the gear and the torch mount does glide across the whole length smoothly. I will check it again in the morning then call or pm you back. Thanks
  2. #12
    Nov 2009
    Abq, NM
    47
    Problem solved!! (hopefully....)
    The first time the motor/control did have a problem but this time was just a false alarm. Moral of the story: keep your gear rack well lubed! I sprayed some white lithium grease on the gear rack and it seemed to have fixed the problem. I cleaned the gear and v-rails really good first then sprayed the gears. It travels across much smoother now with no stalling or skipping around.
