Warning: preg_replace(): The /e modifier is deprecated, use preg_replace_callback instead in ..../includes/class_bbcode.php on line 2968 Oil filter relocator.
Is a gasket needed when installing the oil filter relocater, part #626? I have the kit and it did not come with a gasket. I see there are gaskets that come with the mid plate but not with the relocater. Any help is appreciated. Thanks guys.
What gasket do you recommend? Is a stock replacement ok or should I use the .007 gasket from you? And if a gasket is needed why is it not included in the kit, shouldn't it be?
How you test if you have a .007 is put it in and tighten two opposing 1/4-20 bolts (there are 7 holding the plate to the T-cover). Take a screw driver and try to turn the pump if it binds or is bound up your stuck using the thicker gasket. For 80% of the used T-cvoers out there the thicker (stock) gasket works fine.
