Thc delay?
Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: Thc delay?
    Bulltear forum member Cook
    Jan 2012
    USA
    13
    Thc delay?
    Where do I adjust the delay before the thc takes over. I thought I knew but now I can't find it?
    Edit...we found a bug in the settings menu the THC delay actual may add to the peirce time. You best bet is under profile THC fault delay (did I say it right?) would be your THC delay.
    Updated for you.
    Apr 2012
    USA
    5
    Where do i get the updated file for the bugfix?
    Borst
    No file change only an update to the post above. Please re-read post #2 the reply to the initial post.
    Dec 2011
    Maine
    115
    Quote Originally Posted by jeepsr4ever View Post
    Edit...we found a bug in the settings menu the THC delay actual may add to the peirce time. You best bet is under profile THC error delay (did I say it right?) would be your THC delay.
    What exactly does this mean? What should I adjust and what should I adjust it to?
    Thanks!
    This freezes THC until your in the cut and not in the pierce.
    If you look on your support disk under DTHCII manual you will see where the DTHC delay setting is. This will allow you precise timing on your DTHC. If you experiencing plunges into the material your DTHC is turning on too fast. To counter this the high end systems have a delay. The system we use allows you to set the delay for accuracy. If you look in your "Cut profile" you will see it. The systems go out with presets for your "cut profile" for use with Hypertherm cutters however they will work with virtually any plasma.
    Dec 2011
    Maine
    115
    Thanks Matt!
    Jan 2012
    USA
    13
    I think in the cut profile it is called THC fault Delay. This is where we adjust the delay before the THC starts?
