Warning: preg_replace(): The /e modifier is deprecated, use preg_replace_callback instead in ..../includes/class_bbcode.php on line 2968 Show the world some routing projects
Had the speed turned WAY down (like 5ipm) just to make sure everything was dialed in. You can see in the video the 48"x48" router table/deck I built that sites over the water-table. It slides on and off very easy. The next step is to build a vacuum setup to keep the dust and dirt contained.
In the background of the video, you can see the thick foam where I did my first 2 practice cuts before moving to wood.
