Oil Filter Relocation Plug ???
Results 1 to 3 of 3
Thread: Oil Filter Relocation Plug ???
    Apr 2006
    DeRidder, LA
    7
    I've searched this forum and found the port on the relocation block labeled "plug" is a standard plumbing type plug but never found a size. Is it a 3/8" plug? I was digging around and found a 3/8 plug will go in a couple of threads but gets pretty tight. I want to ensure I use the correct size to avoid gauling the threads on this thing....Can someone give me the skinny on this port?
    Casey
    That is correct. Lube the threads with teflon tape and turn in tight.
    Apr 2006
    DeRidder, LA
    7
    Great...thanks.
