WALT'S 1968 AMC AMX - Page 14
Page 14 of 16 FirstFirst ... 41213141516 LastLast
Results 131 to 140 of 152
Thread: WALT'S 1968 AMC AMX
  1. #131
    Nov 2012
    SACRAMENTO CA
    124
    Just ordered 3.5 in inlet alum. pipe for new inlet,and 3 in for discharge thu the intercooler. anyone need my old setup it would be ok for a 360 in motor, Walt
  2. #132
    Nov 2012
    SACRAMENTO CA
    124
    Well I changed the intake to 3.5 in. tube and the discharge to 3 in. After the hollidays back to the dyno at Motor Machine in Sacramento. Darn I forgot how to post pictures ?
  3. #133
    Nov 2012
    SACRAMENTO CA
    124
Size:  98.2 KBName:  IMG_1160.jpg
Size:  97.3 KBName:  IMG_1161.jpg
  4. #134
    Sweet
  5. #135
    Nov 2012
    SACRAMENTO CA
    124
    WALT'S AMX
    Sweet
    Don at Motor Machine dos not give up, car made good numbers without the entercooler but not with it. He changed the angle of the air inlet to the carburetor and it started to come alive changing jets etc . Then the cast vibration dampener cracked . Last numbers were around 430 HP. and 530 TOR. . Now waiting for a new steel dampner.
  6. #136
    Nov 2012
    SACRAMENTO CA
    124
    Well darn it new problem the baffles coming loose in the mufflers ,I told him change them 3 in flowmasters 3 in pipe over the rear end, the muffler shop said cant do it.but Don said he can cost more ,a lot more time.Name:  IMG_1170.jpg
  7. #137
    Oct 2004
    Upstate NY
    32
    tensioner
    Beautiful setup but the tensioners on the bulltear setup do not appear to be spring loaded. How do u maintain or even tighten belt?
    78' CJ5, 304/435/300/44/60/37's/93wb
  8. #138
    Nov 2012
    SACRAMENTO CA
    124
    Dont have one, plan on doing some tging at least a turnbluckle.
  9. #139
    Alternator bracket allows you to tension. Gates belts have very very little stretch and a spring loaded idler will give up load with the kind of tension you see in a supercharger setup unless the spring rate is very high.
  10. #140
    Nov 2012
    SACRAMENTO CA
    124
    Yes thank you that would be best, if there is space to mount it. Walt
Tags for this Thread
