WALT'S 1968 AMC AMX - Page 2
Page 2 of 16 FirstFirst 123412 ... LastLast
Results 11 to 20 of 152
Thread: WALT'S 1968 AMC AMX
  1. #11
    Nov 2006
    N. Dighton,Ma
    47
    Walt, what power steering pump did you use?
    vehicle, year, engine?
    i still need to get that.
    Norm
  2. #12
    Nov 2012
    SACRAMENTO CA
    124
    Hi Norm I must have tosed the box ,but I think it fits a big block chevy out of a 78 to 80 pickup.I gave Mat the number. Walt
  3. #13
    Nov 2012
    SACRAMENTO CA
    124
    Norm I think its a 68 to 80 chevy bigblock.
  4. #14
    Nov 2006
    N. Dighton,Ma
    47
    ok, i've got a 89 chevy with a 454 but the pump has a seperate resevoir up higher in the system, i'll check the earlier years.
    Thanks again Walt
    Norm
  5. #15
    Nov 2012
    SACRAMENTO CA
    124
    Norm I think that might be a better way, to use that remote tank pump, I did not want to put that much $ for one. On the plus side you would half to cut that left [finger] off on the back compressor bracket like did. Walt
  6. #16
    Nov 2012
    SACRAMENTO CA
    124
Size:  97.0 KBName:  IMG_0944.jpg
Size:  94.0 KBName:  IMG_0945.jpg
Size:  94.6 KB Can not find a belt that I like this one is ok but addjustment bolt is all the tight. Might relocate the idle pully on alternater bracket. Happy with intercooler mounting.
  7. #17
    Walt here are the belt sizes
    K060883 88.43 effective length
    K060882 88.3 effective length
    K060878 87.82 effective length
    K060876 87.57 effective length
    K060875 87.53 effective lenght
    K060874 87.34 effective length
    K060871 87.03 effective length
    These will matter if you dont have a stock vortech pulley
  8. #18
    Nov 2012
    SACRAMENTO CA
    124
    Thank you but belt to close to power steering pump pully and its hits the bolt head next to it. Matt is sending one more idle pully and I hope I can put it like 4 oclock of power steering pully. That would solve both issues.
  9. #19
    Feb 2007
    pei canada
    16
    Walt
    Had same problem with belt hitting bolts so ordered couuntersunk bolts with allen head centers . These went into front of supercharger and allowed belt to clear heads.I used power steering pump from 08 3500 series GM van. It has remote filler and also accepts my hydroboost line. Only using 2 idlers and seems to fit good. Unit fits good in 68 rebel wagon , much better than i expected .
  10. #20
    Nov 2012
    SACRAMENTO CA
    124
    Wow I wish I had that info. sooner.I am to far into this now. THank you
Tags for this Thread
