Page 6 of 16 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 152
Thread: WALT'S 1968 AMC AMX
  1. #51
    Nov 2012
    SACRAMENTO CA
    124
    Spacers look ok find out after supercharger is in. I see the bracket that holds the water pump idle pully on needs some grinding for the lower radiator hose clearance, idle pully bolt cut on the back side also.
  2. #52
    Nov 2012
    SACRAMENTO CA
    124
Size:  88.2 KBName:  IMG_0998.jpg
  3. #53
    Nov 2012
    SACRAMENTO CA
    124
    Happy day things look good supercharger pully shoud go back a little,called Vortech put on hold forver,hung up. Mechinc buddy come by tomorow look see. Power steering hose almost solved. The pressure fittings on the pumps are interchangeable ,makes it a lot easier to get one.
  4. #54
    Nov 2012
    SACRAMENTO CA
    124
Size:  81.4 KBName:  IMG_1006.jpg
  5. #55
    Nov 2012
    SACRAMENTO CA
    124
    Still could not get alinement right , took it all apart again. Found that hump on the lower front of power steering pump barely toching the bracket. Ground a little off the bracket, thats history. Now I came to the conclusion that the two bolt holes for the long water pump bolts in bracket not alined to holes in water pump.Going to get friends for a second opinion.
  6. #56
    Nov 2012
    SACRAMENTO CA
    124
  7. #57
    Nov 2012
    SACRAMENTO CA
    124
    The best day yet, opened up the bolt holes and Wow looks good maybe supercharger pully could go back a fraction ? But I think I will stop here, have to remake some water pump spacers.
  8. #58
    Nov 2012
    SACRAMENTO CA
    124
Size:  95.5 KBName:  IMG_1014.jpg
Size:  95.1 KBName:  IMG_1015.jpg
  9. #59
    Nov 2012
    SACRAMENTO CA
    124
    Well AMC friends good day here ,work on it tomorow, lucky I'm retired.
  10. #60
    Nov 2012
    SACRAMENTO CA
    124
Tags for this Thread
