Warning: preg_replace(): The /e modifier is deprecated, use preg_replace_callback instead in ..../includes/class_bbcode.php on line 2958 jamscal's 5x10 Gantry Build - Page 2
Water table arrived today... they didn't break the ends per the drawing but included the end caps I'll have to weld on. Got a start on it.
They knocked $60 off the price. Said they couldn't bend it.
Found some pipe couplers and turned them down on the lathe to fit into holes I've yet to drill. I'm going with two drains at opposite corners.
Capped the lower tube ends with more of a fish plate. A little overkill but better looking than a square. I want to cap the uppers but think I may need access inside the tube???
The gantry should be on its way down the road and I hope to have it Friday.
Sheetcam/mach3 are on your blue support disk. Bobcad has your customer # and password on the actual case. It is best to quickly hook your PC to the internet and do the registration online with bobcad...takes 25 seconds to send the data when you go to help/register online in bobcad.
