Originally Posted by
jamscal
Current issues:
1.
X home is enabled 1,11 active low
Limit overload is also on 1,11 (not active low)
Instructions say to make sure no two things are on the same pin...what should be where? Disable X home that is an option you can add later for the torch breakaway
2.
THC On/Off blinking green and apparently not working. Check to make sure ccc_comcandcnc plug in is enabled. Go to config/plugins in Mach.
3.
Z axis loses zero. Something to do with THC? See #2
4.
Long delay after pierce and before start (running .3 or .5 sec pierce delay...it's much longer). See #2
5.
The few parts I've run are 1/8" undersized, i.e. 6" circle is 5 7/8. I have the offset right and the kerf right too. PM sent about tuning
That's it for now. I'm sure in my excitement I've done something wrong and I'll be reading more to try to solve my own problems, but any help on the above will be helpful.
James
