cam bearings
Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: cam bearings
    Jan 2013
    NorCal
    49
    cam bearings
    I just recently had my 304 rebuilt...do the cam bearing holes need to be installed or oriented a certain way? These are just stock replacement bearings by the way. I'm asking because the front bearing hole appears to be half way showing oil groove in block.
    There is a slot they meet up with so yes they need to be oriented the right way.
    Jan 2013
    NorCal
    49
    I'll take a picture later to show what I mean.
    If you have the set with the dual hole the large hole goes up.
    Jan 2013
    NorCal
    49
    Single hole bearings...front bearing hole is toward passenger side if block, roughly 7-8 O clock.
    That's how they get oil
    Jan 2013
    NorCal
    49
    Yes thanks, I will post a pic to see what I mean.
    Jan 2013
    NorCal
    49
    Does that look right?
    Not good they dont line up with the hole.
    Jan 2013
    NorCal
    49
    Point I was making......I wanted to make sure.
