AMC 390 Stroker Engine Build Final
Results 1 to 9 of 9
Thread: AMC 390 Stroker Engine Build Final
    Bulltear forum member Cook
    Mar 2012
    ÐÎÑÑÈß
    11
    So, here goes. I'm sure I will leave something out but I will try to remember all the details.
    Clearancing the block for the rods
    Honing the early 360 block to 4.165
    Custom grind comp roller cam needs a retainer plate so we machined an alignment tool
    Dont forget to clearance the timing gear for the retainer
    Finishing up the big end then cutting .014 off the little end to keep the rod from binding
    .027 off the 6" eagle rods to make them fit the crank
    2.055 Int and 1.710 exh valve from a 351 Cleavland since we needed taller valve stems for the roller cam/springs
    Now we can cut the reliefs (flat tops only in the race class)
    Studin out the block
    Fitting the cam
    Mar 2012
    ÐÎÑÑÈß
    11
    Big ole nasty push rods from Comp (FYI ARP 6point nuts wont fit half the head holes)
    Checking the piston to valve clearance so we can cut as much off the heads as possible
    Don't forget to degree the cam (Piston tops are cut down so we are .010 out)
    Putting the top end together
    Finishing all the dressing, getting ready to take it next door for install
    5.5" Mini clutch for a neutral balanced chevy clutch and an early to late flex adapter. (1972 390 crank)
    You can now see how the adapter changes from flex plate to clutch with a late model Chevy V6 roller pilot bearing (Dirrect drive Saginaw trans)
    Mini clutch all buttoned up. It's so little.
    And finally, the turd dirt track car this thing pushes around at 7600 rpm. Can't find an AMC car cheap enough or would I waste one on this stuff.
    I started off to build a 388 stroker but a last minute piston change (I scratched the cylinder wall) and,
    Congratulations I have successfully built a 390!
    :) good work!
    Mar 2012
    ÐÎÑÑÈß
    11
    Quote Originally Posted by jeepsr4ever View Post
    :) good work!
    Thanks, and thank you for all your help with knowledge base, parts, and keeping these engines alive. I have purchased many quality parts and used this board to find out all kinds of things.
    What did you do with the head studs that are below the exhaust ports? Those are always a problem when trying to fit headers.
    Mar 2012
    ÐÎÑÑÈß
    11
    I had to cut the extra stud material off of a few and replace the others with ARP bolts I already had. I use over the rail step heads now and they would have eliminated the problem. I also had a problem with the studs under the guide plates. All of those had to have .25 to .375 cut off.
    Jan 2013
    NorCal
    49
    Nice build....
    Mar 2012
    ÐÎÑÑÈß
    11
    Thanks. I have problem though. Does anyone have a 390 crank for sale? Rod journals will be ground to 2.100 so I can be well used. I spun number one and two rod journals in my race last week. I had 55psi top end 25 idle and i was told, by my engine guy, that it was perfect since he clearance it .00325 on main bearings. Motor didn't shell but it went down on power and I shut it down but the damage was done. Race can be viewed on youtube under WWRT88W channel. Thanks for any help. I have a lead on a 401 crank but don't want to waste it by offset grinding it to 390 stroke.
    Jan 2013
    wyoming
    1
    I have a couple 390's, have not opened them to see condition I would rather sell complete and not piece them out I'm in wyoming
