Proton Z Axis retrofit for Star-Lab machines
Thread: Proton Z Axis retrofit for Star-Lab machines
    Post Proton Z Axis retrofit for Star-Lab machines
    Any Star lab currently bought from 8-1-2015 will have a Proton Z axis on it. For those with the Mag-Lok Z axis you can upgrade to the latest Z axis assembly.
    1606 true ball screw (lubed, double seal, double anchored)
    25MM rails (Lubed, twin triple seal with scraper on each)
    Z axis limit top and bottom included
    Magnetic breakaway (MAG-LOK v.2.)
    Powder coated sheet metal enclosure with quick access
    5/8" thick back panel with Star-Lab adaptor
    Torch bodies up to 2.00"
    Integrated with 800 RPM motor (When installed on Star-Lab CNC with Proton Z axis)
    Up to 4.5hp router capable
    Angular compass up to 65 degrees (from 0 to 60 degree angle cuts (infinite ratio)) available soon
    Twin pocket auxiliary tool pockets with 3 tapped holes for rigid tool bracket mounting
    More info in our E-store www.Plasmaland.com
    Sep 2019
    Black Earth
    11
    Z retrofit
    This is the BT/Starlab-ready version of: Super Zx Z Axis Assembly with torch holder, correct?
    I have a late 2014 non-Proton Starlab with MagLock assy. Cost for retrofit? (assuming we'd use same stepper for Z)
    No info for upgrade/retrofit on plasmaland/starlabcnc sites
