Warning : preg_replace(): The /e modifier is deprecated, use preg_replace_callback instead in ..../includes/class_bbcode.php on line 2968
Wire locks - Order 5610
Bulltear forum member
Cook
Hi,
Somehow I lost my wire locks, i am sure they were shipped because I remember to see them.
Today I took my block and pistons to the machinist and realise no wire locks were in the box.
Do I really need them? Am planning to use OEM 242 (4.0) connecting rods with 258 crankshaft. Are these rods "floating"
My offset pistons have a dish volume of 20 cc
Please see attached file, it says the part number is 927-072-WL.
Also, I found this:
http://www.krammloxusa.com/race-tech.html .
If I really need them, do you sell it and are you able to do fast shipping?
Leonardo Colina.
Thank you from BT
ULTIMUS MAXIMUS STATUS
Your rods are a press fit you will not need the wire locks
Featuring www.StarLabCNC.com [/URL] for CNC plasma machines
Cook
Cook
Hi,
Turns out that the machinist tested the pin in the stock 4.0 rods I have (stock brand new). They fit tight, but no need to press fit. The machinist said I need to use the wire locks. A friend told me I must bush the rods.
What way should i go?
Leonardo Colina.
Cook
I have been told that stock pins are 0.931" diameter.
The specs sent by Racetec says 0.927".
There is a difference of 0.931-0.927= 0.004"
Thank you from BT
Specs are generic for the most part. That piston was made for the stock pin.
Cook
I have no doubt the piston was made for stock pin. The problem is the pin racetec sent. It does not press fit the piston. In the specs sent by Racetec it says the pin is 0.927". Summitracing says the stock pin is 0.931".
Thank you from BT
Did you try the pin or are you guessing from reading the specs?
Cook
Yes I Tried the pin. This photo was taken with my phone. I have here with me one rod, one piston and one pin if you need me to take more pictures.
Right now I only see 3 options:
Request to the machinist to make some bushings. 0.004" seems imposible to make. Order a new set of wire locks and use them. Some people say it is not recommended to use float setup with non-floating rods. Buy locally stock 4.0 pin.
I just want my engine to have the best option, what do you recommend?
Thanks.
Thank you from BT
The lock may be a .927 which will work for you. But the pin should be .9308 in measurement. I suggest you measure the pin.
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
Forum Rules
