sheetcam offset problem
Results 1 to 3 of 3
Thread: sheetcam offset problem
    Helpfull BT forum member Admiral of the Forum
    Oct 2015
    medford wisconsin
    66
    I am having a problem in sheet cam with the offset. I have tried changing from outside to inside and it stays at no offset. its a simple drawing with strait lines and some arcs and no holes. Thanks for any help, Gary
    Gary try saving the file under a different name. Often times new users keep saving the file but reopen the old file.
    Sep 2012
    USA
    23
    Do you have the tool set up with the correct kerf width? If there is no kerf width then sheetcam will run the torch down the middle of the line.
