I'm rebuilding a 304 in my 73 jeep. I found a set of heads prolly 70 to 72 the ones with non adjustable studs. I used SBC studs so I can adjust them.
Ok so the question is I have one bent exhaust valve and have ordered 3 to date all the wrong ones?
The exhaust valves in my motor are the 1.406 head, 4.892 long. The valve is a single groove. Here's the kicker the top edge of the groove to the top of the valve is 0.200
All the valves I have ordered are 0.250 plus
This will not give me the 1.82 installed height I need to match all the others..
It's not just the distance from groove to top or I'd just grind it, it's where the groove is on the stem that's messing me up.
I can use a 4 groove and the height is close enough to shim the spring 0.10 but I preffer not to do that.
Anyone shed any light on this issues. Did the 70 to 72 heads use weird valves compared to all others?
Or do I just have someone's weird combo they put together..
Thank you very much to anyone that can shed some light on this. Denco
