Brand new head gasket leaking
Results 1 to 10 of 19
Thread: Brand new head gasket leaking
    Oct 2015
    Charlotte, NC
    23
    So I tore down an old 360 and had it machined 0.030 over, crank 10/10 , new camshaft and lifters, new springs, heads done completely.
    Got it running for about 20 minutes to break it in and seemed to be running well. Fast forward to starting it up again a week later, and I see there is coolant in the oil. No visible leaks, spark plugs look fine. Just coolant in the oil, and fresh coolant on the valve springs and rockers.
    I end up pulling the intake manifold and reseat it with valley pan and fresh RTV. All good? Nope.
    Next day I'm prepping to restart it, and I see that there is coolant on the oil pan, starter, coming from the passenger side head on the corner.
    I assume its the head gasket, so I loosed the head bolts and retorque them all 35-65-95-110 ft lbs. Should be good?
    I run the engine briefly, and I can see the coolant start to drip strongly on the ground. Cut it off quick. Looks like half way down the passenger side head to the back corner of the head, under the head gasket is leaking coolant.
    So where I am now, engine refresh with all new seals, leaking coolant on the middle to back of the passenger side head gasket. What could cause this so quickly? Why would it leak more after retorqueing the head bolts? I thought that would help.
    Any suggestions welcome, Thanks in advance.
    Shawn
    Hate to say it, but it's pretty common for AMC heads to crack at the bottom corners. There was a sharp corner left in the casting and they stress crack. Chances are that it cracked when you torqued it down with a new head gasket. That's why it's very important to follow the factory sequence, and tighten in 3-4 steps. The only way to tell is pull the head and take it back to the shop for a magnaflux.
    What brand head gasket? Is it composite? I usually use Fel-Pro, head side dry, block side coated with spray copper. It's important if the block wasn't decked. The solid metal side goes toward the block, be sure you didn't install them upside down.
    Oct 2015
    Charlotte, NC
    23
    Thanks Bob. I did tighten in factory order and with progressive torques, and the heads were checked at the machine shop. Nonetheless, sounds to be a common problem that matches my symptoms. Only other thought I had was the head bolts being old are not working well. But they seem to be holding 110 ft/lbs. I considered replacing those as a minimum easy fix before going the whole way down. Anything else I could test?
    If you could find someone with a coolant system pressure tester I suppose you could attach that and pressurize the coolant system and look for leaks. It may only leak when the engine is warm though. Usually when the heads crack at the corners they only leak to the outside. My first guess with coolant in the oil would have been the intake, but you covered that. I know it's a lot of re-work, but I'd pull the leaking head and have it checked for cracks.
    Oct 2015
    Charlotte, NC
    23
    That's the plan, I'll be pulling the head tonight. Clearly fresh coolant leaking pretty good between head gasket and block on bottom side. Will get head to machine shop tomorrow.
    Should I be worried about the block? Anything else to change? One local guy said I should change the pickup since coolant was running shortly in the engine.
    Oct 2015
    Charlotte, NC
    23
    Bob, quick update, got new head bolts from this great engine shop in Belmont. $15. The 14 bolt had a good amount of white coolant on it when I took it out.
    Installed and retorqued in order in 4 stages (35, 65, 95, 110), and without starting it looks like the 13 bolt is leaking coolant out very bottom left of head. But I haven't done full compression yet to see if other places are leaking.
    Does this still sound like a head thats cracked, or could it be a head gasket only? (praying this one!) Thanks, Shawn
    That's where the heads usually crack, either 12 or 13 (the end short bolts). There shouldn't be coolant on any of the bolts, all should be blind holes. I would check that #14 bolt hole to be sure it hasn't cracked into the water jacket. It's just really hard to tell without pulling the head.
    Oct 2015
    Charlotte, NC
    23
    Ok, will be pulling the head today and checking all of the above. Plan to get the head back to the machine shop to check it fully tomorrow.
    Oct 2015
    Charlotte, NC
    23
Size:  96.0 KBName:  IMG_7145-1.jpg
Size:  95.3 KBName:  IMG_7143.jpg
Size:  91.5 KBName:  IMG_7147.jpg
Size:  93.8 KBName:  IMG_7148.jpg
Size:  96.8 KBName:  IMG_7140.jpg
Size:  90.3 KBName:  IMG_7142.jpg
Size:  91.6 KBName:  IMG_7144.jpg
    Jim, I got the head off, but don't see anything out of the ordinary. I looked for cracks, but don't see any to the naked eye. Is there an exact spot to look?
    I'll be hitting the machine shop in the morning to magnaflux and test.
    What is the casting number? If it is a 291 then your almost guaranteed a crack in the corner. They cut the head at a strait 90 degrees which leads to cracks right there. Not much pops out in the pictures except that lousy mark in your piston.
Tags for this Thread
