Warning: preg_replace(): The /e modifier is deprecated, use preg_replace_callback instead in ..../includes/class_bbcode.php on line 2968 Windows 8.1 Works!
Just wanted to let you know we got everything going on the new PC (went through and optimized) We are getting great cuts and no crashes. Been a rough 2 months but it's dialed finally, thanks for the help!
Just need to dial in the settings for finecut aluminum since their are none. If you have the setting I'd love to have them!
I also changed some of your wiring - different cables/wires/locations/routing and Cat6 :)
Be careful with Cat 6 cables they use a metal shielded outer retaining clip that will be a source of noise. They are not a viable upgrade for a good cat5. I hope 8.1 will continue to work for Cris.
Featuring www.Plasmaland.com for CNC plasma machines
