Hey Guys,
I installed your setup on my 69 AMX, I have had a hard time keeping my belt from coming off at high RPM's. I have to put a lot of tension the belt VIA the alternator in order to get it to stop squealing, when I do this it seems to tweak the alternator a little bit which is obviously causing the belt to come off.
Is there a Spring Tensioner option so i can avoid having to put all the pressure on from my alternator? Have you heard of any other customers having an issue? Any Suggestions? The setup is Running Water Pump, Power steering and Alternator.
Brad
