Results 1 to 5 of 5
Thread: help would be appreciated
    Bulltear forum member Swabie
    Mar 2006
    chetopa ks
    25
    Exclamation help would be appreciated
    Have a jeep Cherokee that I have been driving it has carried 15to 20 lbs of oil at idle. I ordered and installed a set of hrc gears and oil filter adapter. When I first started it had good pressure . Let it set over night have no pressure and lifter chatter. Removed pressure relief and cleaned and checked. Still no pressure and lifter noise any help would be appreciated has new ac delco filter also.
    torque till turns freely
    Mar 2006
    chetopa ks
    25
    went and removed gears reprimed , pressure back let set more than hour , oil pressure gone. Any ideas possible bad pickup ?
    2,837
    Any leaks? The gears should stay filled with oil. If no leaks, try a different brand filter. I prefer Wix or NAPA gold. Please tell me you’re not using a Fram.
    2,837
    Sep 2019
    France
    4
    going through this now . got to check everything in the oil circuit with a fine tooth comb .
