Roger all, different than cooling hot metal or suppressing electronic noiseOriginally Posted by Tigger
I - R - ed-u-ma-cated a bit better :lol:
="While we are on the topic of pistons......
The stock piston is Dished - Have no clue what the cc is, but it has almost NO Quench. I have read about getting quench from pistons, deck height, head gaskets etc.... but for purpouses f this matter, allow me to play dumb and ask, Where can I find AMC specific pistons, adapted with quench, and what range of quench would be safe. Taking into account the shifting or rocking of the piston, is 0.020 enough - EXTREMELY high quench, or would 0.040 - essentially Zero Deck Clearance, and a Proform Head Gasket, Be enough quench?
I have heard that to push a quench of 0.037 to 0.030 on non-alumnium heads will outperform Alumnium heads? What validitiy/reliability can you credit to this, and from your experience?
What are the extremes?
Mike M
.020 is too close. Effective quienh is right abou .035-.045. Stock Amc pistons don't lend themselves to quench which is why I am going with custom pistons. From talking with Venolia they will look something like the 4.0 pistons with the "D" in them. Then dish down so I can still get a resonable compression ratio.
-RJ
The AMC pistons have notches on the crown, just outside of the valve relief, visible from the head side, even after installation. Notch to the front of the engine. I can post a pic, but don't have one scanned in at the moment...Dave
PS: another cool thing about the AMC geometry is that if piston hits valve, you bend pushrods, not valves and split guides. I found this out when my timing chain jumped, then jumped back so I could get home!
Nostalgia ProStock.
Interesting - I tried to fix the link and it won't come in??? Cut and past works, but not IMG??
