Warning: preg_replace(): The /e modifier is deprecated, use preg_replace_callback instead in ..../includes/class_bbcode.php on line 2958 Install a postal jeep dana 44 in a narrow track CJ
ok first youll need to grind off the purches
next make sure you clean the lube out(ok you dont have to change the lube if you dont want to, Lazy bones) Hey look the parts guy said this is a dana 44 gasket.HMMMM i wonder om what planet this gasket fits a dana 44
You will want to space the axle evenly from spring to spring, this is 3.5"s from backing plate to spring on either side with a cj 36 on center spring set up
