Tech Dana 60
Results 1 to 5 of 5
Thread: Tech Dana 60
    Tech Dana 60
    Factory ratios 3.54-7.17
    Mostly full floating rear (ex. dana 60-2 (five lug) and 60-3 (8 lug))
    Weak point factory cross pin
    spline counts 16,23,30,32,35
    60 cast in pumkin housing
    DANA Axle ID / Bill of Material Numbers
    For quick ID reference, Dana puts the model # (28, 30, 44, 50, 60, 70, 80) raised in the casting of the center housing. All Dana axle assemblies are also marked by both a stamped # in one of the axle tubes and labeled by a metal tag attached to a cover bolt. Once this "Bill Of Material" is found, the # can be cross referenced in a DANA XGI and Manufacturer Catalog. The "Bill Of Material" will always start with '60' or '61' followed by four digits, a dash, and one or two final digits.
    Example: of a "B.O.M. #": 610445-2 = Ford Model 60 FRONT 1994 - F350
    Complete Bill Of Material information:
    Bill of Material Number Manufacturer Model Front / Rear Application
    603470 JEEP 60 REAR 1979 J20 PICKUP
    603643 CHRY 60 FRONT 1979-80 D-600
    603647 CHRY 60 REAR 1979 D-200 & W-200 H.D.
    603651 CHRY 70 REAR 1979 M-300 & M-400 MOTOR HOME (2pc STD CASE)
    603652 CHRY 70 REAR 1979 M-500 MOTOR HOME
    603653 CHRY 70 REAR 1979-83 P-300
    603683 JEEP 44 FRONT 1978-79 WAGONEER / CHEROKEE
    603685 JEEP 44 FRONT 1978-79 J10, J20, HONCHO, CHEROKEE WIDE TRACK
    603695 CHRY 70 REAR 1979 D-300/400 &W-300/400
    603696 CHRY 70 REAR 1979 D-300 SWEPTLINE
    603702 GM 60 REAR 1979 DRW G-VAN 146" WB - FULL FLOAT
    603703 GM 70 REAR 1979 G-300 146" WB - 70B
    603704 GM 70 REAR 1979 C-30 DUAL WHEEL - 70HD
    603725 FORD 60 REAR 1979 F-250 CREW CAB - FULL FLOAT
    603732 JEEP 30 FRONT 1978 CJ5/CJ7 - EXTERNAL TYPE WHEEL END
    603815 JEEP 44 REAR 1977-79 CHEROKEE CHIEF (STD TRANSFER CASE)
    603816 JEEP 44 REAR 1977-79 WAGONEER & CHEROKEE (STD TRANSFER CASE)
    603817 JEEP 44 REAR 1977-79 WAGONEER & CHEROKEE (QUADRA-TRAC TRANSFER CASE)
    603818 JEEP 44 REAR 1977-79 CHEROKEE CHIEF QUADRA-TRAC
    603820 JEEP 44 REAR 1977-80 POST OFFICE DISPATCHER
    603831 CHRY 60 REAR 1979 RAIL MAINTENANCE
    603841 CHRY 70 REAR 1979 WM 300
    603884 GM 60 REAR 1979 DRW G-VAN 125" WB - FULL FLOAT
    603901 FORD 60 REAR 1979 F-250 4X4 - FULL FLOAT
    603909 FORD 70 REAR 1980 AMBULANCE - 70HD
    603916 CHRY 70 REAR 1979-84 CB-400 & MB-400
    603917 CHRY 60 REAR 1979 D-200 & BD-600
    603918 CHRY 70 REAR 1979-84 CB-300 H.D. & MB-400 H.D.
    603919 CHRY 60 REAR 1979 MD-300 DUAL WHEEL H.D.
    603920 CHRY 60 REAR 1979 B-300 MAXIVAN H.D.
    603925 FORD 61 REAR 1979 F-250 4X2 - FULL FLOAT
    603926 FORD 60 REAR 1979 F-250 4X2 - FULL FLOAT
    603929 GM 70 REAR 1979 P-300 MOTOR HOME - 70HD
    603930 JEEP 60 REAR 1978-79 J20 PICKUP
    603932 FORD 61 REAR 1979-80 E-250 - FULL FLOAT
    603934 FORD 70 REAR 1979-80 E-350 VAN - 70HD
    603935 FORD 70 REAR 1979 F-350 PICK-UP - 70HD
    603936 FORD 70 REAR 1979-80 F-350 U-HAUL - 70B
    603937 FORD 70 REAR 1979 F-350 CHASSIS - 70HD
    603938 FORD 70 REAR 1979 E-350 CHASSIS - 70HD
    603940 FORD 70 REAR 1979-80 E-350 CHASSIS - 70HD
    603941 JEEP 44 REAR 1979 J10 & HONCHO TRUCK
    603943 FORD 60 REAR 1980-81 F-250 3/4 TON 4X2, 4X4 PICK-UP - SEMI FLOAT
    603944 FORD 61 REAR 1980 F-350 4X2 CHASSIS - FULL FLOAT
    603946 FORD 61 REAR 1980-81 F-250 4X2 - SEMI FLOAT
    603947 FORD 61 REAR 1980 F-350 4X2, 4X4 PICK-UP - FULL FLOAT
    603949 FORD 70 REAR 1980 F-350 BIG DOOLEY - 70HD
    603955 CHRY 70 REAR 1979-83 WM-300
    603962 FORD 70 REAR 1980 F-350 CHASSIS - 70HD
    603967 GM 44 REAR 1980 CORVETTE
    603970 GM 70 REAR 1979 P-300 UPS - 70HD
    603971 CHRY 60 REAR 1979-84 HIGH PERFORMANCE RACING AXLE (SEMI FLOAT)
    603972 CHRY 60 REAR 1979-84 HIGH PERFORMANCE RACING AXLE (SEMI FLOAT)
    603973 FORD 44 REAR 1979 F-100 & F-150
    603980 JEEP 60 REAR 1980-81 1/2 J20 PICK-UP
    603987 GM 70 REAR 1979 P-300 UPS M- 70HD
    609389 CHRY 60 REAR 1980-88 1/2 RAIL MAINTENANCE/D-200 & D-600
    603990 CHRY 60 REAR 1980-84 C-300 & B-300 MB-300 H.D.
    603992 CHRY 60 REAR 1980-82 D-200 & W-200 H.D.
    603993 CHRY 60 REAR 1980-84 MB-300 DUAL WHEEL H.D.
    603994 CHRY 60 REAR 1980-88 1/2 B-300 MAXIVAN H.D.
    603995 CHRY 70 REAR 1980-84 D-300/400 & W-300/400
    603997 CHRY 70 REAR 1980-83 M-300 & M-400 MOTOR HOME
    603998 CHRY 70 REAR 1980-83 M-500 MOTOR HOME
    605000 GM 60 REAR 1980-82 DRW G-VAN 125" WB - FULL FLOAT
    605001 GM 60 REAR 1980-82 DRW G-VAN 146" WB - FULL FLOAT
    605002 GM 70 REAR 1980-82 G-300 146" WB - 70B
    605003 GM 70 REAR 1980-81 C-30 DUAL WHEEL - 70HD
    605004 GM 70 REAR 1980-81 P-300 MOTOR HOME - 70HD
    605005 GM 70 REAR 1980-81 P-300 UPS - 70HD
    605020 FORD 60 REAR 1980 1/2 E-250 - FULL FLOAT
    605022 FORD 61 REAR 1981-83 E-350 DRW CHASSIS - FULL FLOAT
    605030 FORD 61 REAR 1981 E-250 VAN - SEMI FLOAT
    605031 FORD 60 REAR 1981-81 1/2 E-250 VAN - SEMI FLOAT
    605038 FORD 70 REAR 1981-83 F-350 CHASSIS DSO DUAL WHEEL - 70HD
    605039 FORD 61 REAR 1981-83 F-350 CHASSIS - FULL FLOAT
    605040 FORD 61 REAR 1981-83 F-350 - FULL FLOAT
    605042 FORD 70 REAR 1981-82 E350 CHASSIS - 70B
    605043 GM 70 REAR 1985-89 P-300 UPS - 70HD
    605044 FORD 70 REAR 1981-83 F-350 HEAVY DUTY CHASSIS - 70HD
    605045 FORD 70 REAR 1981-83 F-350 DUAL WHEEL - 70HD
    605053 FORD 70 REAR 1981-85 E-350 DSO - 70HD
    605054 FORD 70 REAR 1981-83 F-350 U-HAUL - 70HD
    605055 FORD 70 REAR 1981-82 F-350 DSO AMBULANCE - 70HD
    605056 FORD 61 REAR 1981-83 3-350 SCHOOL BUS - FULL FLOAT
    605057 FORD 70 REAR 1981-82 E-350 SCHOOL BUS - 70B
    605062 GM 44 REAR 1981-83 CORVETTE
    605064 FORD 61 REAR 1981 E-250 VAN - FULL FLOAT
    605068 GM 70 REAR 1980-81 P-300 MOTOR HOME - 70HD
    605079 JEEP 60 REAR 1982-85 J20 PICK-UP
    605080 FORD 70 REAR 1981 1/2-83 E-350 DSO - 70B
    605082 CHRY 60 REAR 1983-84 D-300 HD
    605086 FORD 60 REAR 1982-83 F-250 - SEMI FLOAT
    605087 FORD 61 REAR 1982 F-250 - SEMI FLOAT
    605088 FORD 61 REAR 1982-83 E-250 VAN - SEMI FLOAT
    605089 FORD 60 REAR 1982-83 E-250 VAN - SEMI FLOAT
    605096 GM 70 REAR 1981 1/2 P-300 UPS - 70HD
    605099 GM 70 REAR 1982-84 C/K-30 - 70HD
    605101 FORD 70 REAR 1981 1/2-83 E-350 DSO - 70HD
    605103 JEEP 44 REAR 1982-84 CJ10
    605104 JEEP 60 REAR 1982 1/2-84 CJ10
    605114 FORD 70 REAR 1982 1/2-83 E-350 DSO CHASSIS - 70U
    605115 FORD 70 REAR 1983 E-350 DSO CHASSIS - 70U
    605117 GM 70 REAR 1982 1/2-87 P-30 MOTOR HOME/DISC BRAKES - 70HD
    605118 FORD 70 REAR 1982 1/2-83 F-350 DSO WIDE TRACK - 70HD
    605132 GM 60 REAR 1983 DRW G-VAN 125" WB - FULL FLOAT
    605133 GM 60 REAR 1983 DRW G-VAN 146" WB - FULL FLOAT
    605134 GM 70 REAR 1983 G-300 146" WB - 70B
    605138 FORD 70 REAR 1982 1/2-83 1/2 F-350 DSO AMBULANCE - 70HD
    605139 FORD 70 REAR 1982 1/2-83 E-350 DSO - 70B
    605143 FORD 70 REAR 1983 1/2 E-350 DSO - 70B
    605145 FORD 60 REAR 1983 1/2 F-350 PICK-UP - SEMI FLOAT
    605146 FORD 60 REAR 1983 1/2 F-350 CHASSIS - SEMI FLOAT
    605154 FORD 61 REAR 1983 1/2 F-350 PICK-UP - SEMI FLOAT
    605156 FORD 61 REAR 1983 1/2 F-350 CHASSIS - SEMI FLOAT
    605158 CHRY 70 REAR 1985-90 1/2 ISREAL AIRCRAFT
    605169 FORD 60 REAR 1983 1/2-85 F-250 - SEMI FLOAT
    605170 FORD 70 REAR 1984-85 F-350 6 WHEELER - 70HD
    605172 GM 36 REAR 1984 CORVETTE
    605175 FORD 70 REAR 1983 1/2 F-350 CHASSIS - 70U
    605176 FORD 70 REAR 1983 1/2-85 F-350 HEAVY DUTY CHASSIS - 70HD
    605178 FORD 61 REAR 1983 1/2 E-250 VAN - SEMI FLOAT
    605179 FORD 60 REAR 1983 1/2 E-250 VAN - SEMI FLOAT
    605180 GM 36 REAR 1984 CORVETTE
    605192 CHRY 70 REAR 1984-85 D-300/D-450 SWEPTLINE & D-350 & W-350
    605196 JEEP 60 REAR 1985 AM 720
    605197 FORD 61 REAR 1984-85 F-350 - FULL FLOAT
    605198 FORD 61 REAR 1984-85 F-350 & F-350 CHASSIS
    605200 GM 60 REAR 1985-86 DRW G-VAN 125" WB - FULL FLOAT
    605201 GM 60 REAR 1985-89 DRW G-VAN 146" WB - FULL FLOAT
    605202 GM 70 REAR 1984-89 DRW G-VAN 146" WB - 70U
    605203 GM 70 REAR 1984-86 C/K-30 & R/V-30 - 70HD
    605204 FORD 70 REAR 1983 1/2-85 F-350 PICK-UP - 70U
    605205 FORD 70 REAR 1983 1/2-85 F-350 CHASSIS - 70U
    605206 FORD 70 REAR 1983 1/2 F-350 U-HAUL - 70U
    605207 FORD 70 REAR 1983 1/2-85 F-350 DSO AMBULANCE - 70HD
    605208 FORD 70 REAR 1984-85 F-350 CHASSIS - 70U
    605211 FORD 60 REAR 1984-85 E-250 VAN - SEMI FLOAT
    605212 FORD 61 REAR 1984-85 E-350 VAN SRW - FULL FLOAT
    605213 FORD 70 REAR 1984-85 E-350 CHASSIS - 70U
    605214 CHRY 70 REAR 1985 D-300 & D-400 & D-700
    605215 CHRY 70 REAR 1985 D-300
    605218 GM 44 REAR 1984-85 F-CAR
    605220 GM 44 REAR 1985-87 CORVETTE
    605222 CHRY 60 REAR 1985-88 1/2 B-300 (VAN)
    605224 CHRY 60 REAR 1985-85 1/2 D-200 & BD-600
    605225 CHRY 60 REAR 1985-88 1/2 D-200 HD & D-300 H.D.
    605235 CHRY 70 REAR 1985-88 1/2 FRONT SECTION MOTOR HOME
    605236 JEEP 44 REAR 1985 CJ10
    605237 JEEP 60 REAR 1985 CJ10
    605239 GM 36 REAR 1984-86 CORVETTE
    605242 JEEP 70 REAR 1985 CJ 10A MILITARY
    605244 FORD 61 REAR 1985 F-350 - FULL FLOAT
    605246 FORD 70 REAR 1985 F-350 CHASSIS - 70U
    605247 FORD 70 REAR 1985 F-350 CHASSIS - 70U
    605248 FORD 70 REAR 1985 F-350 CHASSIS - 70U
    605249 FORD 70 REAR 1985 F-350 HEAVY DUTY CHASSIS - 70HD
    605250 FORD 70 REAR 1985 F-350 6 WHEELER - 70HD
    605251 FORD 60 REAR 1985 E-250 VAN SRW - SEMI FLOAT
    605252 FORD 61 REAR 1985-86 E-350 VAN - FULL FLOAT
    605253 FORD 70 REAR 1985-86 E-350 CHASSIS - 70U
    605254 FORD 60 REAR 1985 F-250 - SEMI FLOAT
    605255 FORD 70 REAR 1985-87 F-350 DSO AMBULANCE - 70HD
    605260 GM 36 REAR 1985-87 CORVETTE
    605267 FORD 30 REAR 1985 1A AEROSTAR VAN
    605268 GM 60 REAR 1986-89 DRW G-VAN 125" WB - FULL FLOAT
    605269 CHRY 70 REAR 1985 1/2 D-300 & D-400 & D-500 & D-600
    605270 CHRY 70 REAR 1985 1/0 D-300 & D-400 & D-500 & D-600
    605273 FORD 30 REAR 1986-88 1A AEROSTAR VAN
    605285 JEEP 44 REAR 1986 GRAND WAGONEER
    605286 JEEP 44 REAR 1986 J10 PICKUP
    605287 JEEP 44 REAR 1986 XJ METRIC TON TRUCK
    605289 JEEP 44 REAR 1986 CJ7
    605290 JEEP 35 REAR 1986 XJ UTILITY
    605291 JEEP 60 REAR 1986-88 J20 PICKUP
    605292 JEEP 35 REAR 1986 XJ TRUCK
    605293 JEEP 35 REAR 1986 XJ UTILITY
    605294 JEEP 35 REAR 1986 XJ PICKUP
    605295 JEEP 35 REAR 1987-89 YJ
    605298 FORD 60 REAR 1986-88 E-250 VAN SRW - SEMU FLOAT
    605299 FORD 61 REAR 1987 E-350 VAN - FULL FLOAT
    605300 FORD 70 REAR 1987-88 E-350 CHASSIS - DRW - 70U
    605302 GM 70 REAR 1988-90 SRW G-VAN 30 - 70-3HD
    605303 FORD 80 REAR 1988 F-350 SUPER DUTY
    605305 GM 70 REAR 1987 SRW C-30 - 70-3HD
    605370 GM 70 REAR 1988-89 DRW G-VAN 30 - 70-3HD
    605311 CHRY 70 REAR 1987-90 1/2 D-200 & D-300 & D-600 & D-700 W/ABS
    605312 CHRY 70 REAR 1989-90 1/2 D-200 & D-300 & D-600 & D-700 W/ABS
    605313 CHRY 70 REAR 1987-90 D-300 & D-700 W/ABS
    605315 JEEP 35 REAR 1985 1/2 XJ UTILITY
    605316 JEEP 35 REAR 1985 1/2 XJ UTILITY
    605321 GM 36 REAR 1988-90 CORVETTE
    605322 GM 44 REAR 1989 1/2-90 CORVETTE
    605323 JEEP 35 REAR 1987-89 XJ UTILITY
    605324 JEEP 35 REAR 1987-89 XJ PICKUP
    605325 JEEP 44 REAR 1987-93 1/2 XJ METRIC TON TRUCK, XJ HD TRUCK
    605329 JEEP 44 REAR 1987-92 GRAND WAGONEER
    605330 JEEP 44 REAR 1987-88 J10 PICKUP
    605331 GM 70 REAR 1987-91 1/2 R/V-30 - 70HD
    605337 FORD 70 REAR 1988 1/2-89 E-350 U-HAUL CHASSIS - 70HD
    605339 JEEP 44 REAR 1988 1/2-96 1/2 YJ
    605342 JEEP 44 REAR 1987-87 1/2 XJ UTILITY
    605344 FORD 70 REAR 1987 1/2 E-350 CHASSIS - DRW - 70HD
    605345 GM 70 REAR 1987 1/2 SRW C-30 - 70-3HD
    605346 GM 70 REAR 1987 1/2-89 SRW K-30 - 70-3HD
    605351 JEEP 35 REAR 1988-89 XJ UTILITY, TRAILER TOW, ABS
    605352 FORD 70 REAR 1987 1/2 E-350 CHASSIS - DRW - 70U
    605355 FORD 60 REAR 1988 E-350 VAN SRW - FULL FLOAT
    605361 GM 70 REAR 1988 P-30 MOTOR HOME/DISC BRAKES - 70HD
    605363 GM 70 REAR 1988-89 P-30 MOTOR HOME/DISC BRAKES - 70HD
    605365 GM 44 REAR 1988-89 CORVETTE
    605368 CHRY 60 REAR 1989-90 1/2 D-300 & D-700 H.D. W/ABS
    605370 CHRY 60 REAR 1989-93 1/2 D-200 H.D. & D-600 H.D. W/ABS
    605371 CHRY 60 REAR 1989-93 1/2 D-200 H.D. & D-600 H.D. W/ABS
    605373 CHRY 70 REAR 1989-90 D-300 & D-700 W/ABS
    605386 CHRY 70 REAR 1988-90 1/2 FRONT SECTION MOTOR HOME
    605387 JEEP 35 REAR 1988 1/2-89 XJ UTILITY, I-6 AUTOMATIC
    605389 JEEP 35 REAR 1988 1/2-89 XJ UTILITY, TRAILER TOW
    605391 GM 70 REAR 1988-89 P-30 MOTOR HOME/DISC BRAKES - 70HD
    605397 GM 70 REAR 1988-89 DRW C/K-30 - 70-3HD
    605400 FORD 80 REAR 1989 F-350 SUPER DUTY
    605403 GM 60 REAR 1990 DRW G-VAN 146" WB - FULL FLOAT
    605405 GM 60 REAR 1990 DRW G-VAN 125" WB - FULL FLOAT
    605407 CHRY 70 REAR 1989-90 D-300
    605408 CHRY 70 REAR 1989 D-300 WIDE TRACK W/ABS
    605412 FORD 70 REAR 1989 E-350 CHASSIS - DRW - 70U
    605413 FORD 60 REAR 1989 E-350 VAN SRW - FULL FLOAT
    605414 FORD 60 REAR 1989 E-250 VAN SRW - SEMI FLOAT
    605415 GM 70 REAR 1989 1/2 P-300 UPS - 70HD
    605416 JEEP 35 REAR 1990-90 1/2 XJ UTILITY
    605417 GM 44 REAR 1990-90 1/2 CORVETTE
    605418 GM 70 REAR 1989 1/2 G-VAN EXTENDED - 70-3HD
    605419 FORD 60 REAR 1990-91 1/2 E-250 VAN SRW - SEMI FLOAT - ABS
    605420 FORD 60 REAR 1990-91 1/2 E-250 VAN SRW - FULL FLOAT - ABS
    605421 FORD 70 REAR 1990-91 1/2 E-350 CHASSIS - DRW - ABS - 70U
    605423 JEEP 35 REAR 1990-90 1/2 YJ
    605425 JEEP 35 REAR 1990-90 1/2 MJ PICKUP
    605427 JEEP 35 REAR 1990-91 1/2 XJ UTILITY, TRAILER TOW, ABS
    605434 FORD 30 REAR 1989 1/2 1A AEROSTAR VAN
    605437 FORD 70 REAR 1989-90 1/2 E-350 MOTOR HOME - 70U
    605438 FORD 70 REAR 1989-90 E-350 MOTOR HOME - 70HD
    605440 CHRY 60 REAR 1989-94 1/2 B-300 H.D. W/ABS
    605441 CHRY 60 REAR 1989 B-300 MAXIVAN H.D.
    605443 JEEP 35 REAR 1990-90 1/2 XJ UTILITY, I-6 AUTOMATIC
    605444 JEEP 35 REAR 1990-90 1/2 XJ UTILITY, TRAILER TOW
    605445 FORD 80 REAR 1990-91 1/2 F-350 SUPER DUTY
    605449 GM 70 REAR 1990-91 1/2 SRW G-VAN 30 - 70-3HD
    605452 GM 70 REAR 1990 DRW G-VAN 146" WB - 70U
    605453 GM 70 REAR 1990 DRW G-VAN 30 - 70-3HD
    605454 GM 70 REAR 1990-91 1/2 G-VAN EXTENDED - 70-3HD
    605455 JEEP 35 REAR 1988-89 XJ PICKUP
    605456 GM 70 REAR 1989 1/2-90 P-30 MOTOR HOME/DISC BRAKES - 70HD
    605457 GM 70 REAR 1989 1/2-90 P-30 MOTOR HOME/DISC BRAKES - 70HD
    605461 FORD 80 REAR 1992-93 1/2 F-450 CHASSIS-DRW-FULLFLOAT
    605470 GM 70 REAR 1990 P-300 UPS - 70HD
    605471 FORD 70 REAR 1990-91 1/2 E-350 MOTOR HOME - ABS - 70HD
    605475 JEEP 35 REAR 1993-94 ZJ ABS
    605480 FORD 70 REAR 1990-91 1/2 E-350 U-HAUL CHASSIS - ABS - 70HD
    605483 JEEP 35 REAR 1990-92 1/2 XJ UTILITY
    605484 JEEP 35 REAR 1990-92 1/2 XJ UTILITY, I-6 AUTOMATIC
    605485 JEEP 35 REAR 1990-92 1/2 XJ UTILITY, TRAILER TOW
    605487 FORD 60 REAR 1992-93 1/2 E-350 VAN SARW - FULL FLOAT
    605488 FORD 70 REAR 1992 E-350 CHASSIS - DRW - ABS - 70U
    605489 CHRY 70 REAR 1990 1/2 AIR FORCE TOW VEHICLE W/ABS
    605490 GM 36 REAR 1990 1/2-96 1/2 CORVETTE
    605491 GM 44 REAR 1990-96 1/2 CORVETTE
    605492 GM 44 REAR 1990 1/2 CORVETTE
    605493 GM 70 REAR 1990 1/2-92 1/2 P-300 UPS - 70HD
    605494 GM 70 REAR 1991-93 1/2 70HD
    605495 GM 60 REAR 1990 1/2-91 1/2 DRW G-VAN 146" WB - FULL FLOAT
    605496 GM 60 REAR 1990 1/2-91 1/2 DRW G-VAN 125" WB - FULL FLOAT
    605497 GM 70 REAR 1990 1/2-91 1/2 DRW G-VAN 146" WB - 70U
    605498 GM 70 REAR 1990 1/2-91 1/2 DRW G-VAN 30 - 70-3HD
    605499 GM 80 REAR 1992 MOTOR HOME/DISC BRAKES - 80
    605500 JEEP 35 REAR 1991-93 1/2 MJ PICKUP
    605501 FORD 70 REAR 1991-91 1/2 CONTINENTAL BAKERY CHASSIS - ABS - 70U
    605502 JEEP 35 REAR 1991-93 1/2 YJ
    605507 JEEP 35 REAR 1993-94 ZJ T/TOW, ABS
    605508 CHRY 70 REAR 1991-93 1/2 D-200 & D-300 & D-600 & D-700 W/ABS
    605509 CHRY 70 REAR 1991-93 1/2 D-200 & D-300 & D-600 & D-700 W/ABS
    605510 CHRY 70 REAR 1991-93 1/2 D-300 & D-700 W/ABS
    605511 CHRY 70 REAR 1991-93 1/2 D-300 & D-700 W/ABS
    605512 CHRY 70 REAR 1991-93 1/2 D-300 WIDE TRACK W/ABS
    605513 CHRY 70 REAR 1987-93 D-300 WIDE TRACK W/ABS
    605514 CHRY 70 REAR 1991-93 1/2 AIR FORCE TOW VEHICLE W/ABS
    605516 CHRY 60 REAR 1991-94 B-300 MAXIVAN W/ABS
    605517 CHRY 60 REAR 1991-95 1/2 D-300 & D-700 H.D. W/ABS
    605518 FORD 70 REAR 1990-91 1/2 UPS CHASSIS - ABS - 70U
    605522 CHRY 70 REAR 1991-93 1/2 D-300 & D-400 & D-500 & D-600 & D-700 W/ABS
    605524 GM 80 REAR 1992 1/2-93 1/2 GMT 455 - 80
    605525 JEEP 35 REAR 1992-93 1/2 YJ ABS
    605526 GM 80 REAR 1992 1/2-93 1/2 P-TRUCK - 80
    605527 GM 80 REAR 1992 1/2-93 1/2 P-TRUCK - 80
    605528 JEEP 35 REAR 1993-93 1/2 YJ ABS
    605529 CHRY 44 REAR 1993 1/2 VIPER
    605534 JEEP 35 REAR 1992 1/2-93 1/2 XJ UTILITY, STD
    605535 JEEP 35 REAR 1992 1/2-93 1/2 XJ UTILITY, STD
    605536 JEEP 35 REAR 1992 1/2-93 1/2 XJ UTILITY, STD
    605537 FORD 70 REAR 1992 CONTINENTAL BAKERY CHASSIS - ABS - 70U
    605538 FORD 70 REAR 1992-93 1/2 E-350 MOTOR HOME - ABS - 70HD
    605539 FORD 70 REAR 1992-93 1/2 E-350 U-HAUL CHASSIS - ABS - 70HD
    605540 FORD 70 REAR 1992-92 1/2 UPS CHASSIS - ABS - 70U
    605541 JEEP 35 REAR 1992-93 1/2 YJ ABS
    605547 CHRY 70 REAR 1991-93 1/2 D-300 & D-400 & D-500 & D-600 & D-700 W/ABS
    605556 FORD 60 REAR 1992 E-250 VAN SRW - SEMI FLOAT - ABS
    605558 GM 44 REAR 1992 1/2-94 F-CAR
    605559 GM 70 REAR 1993-94 P-300 UPS - 70HD
    605564 JEEP 35 REAR 1992-93 1/2 YJ ABS
    605567 FORD 70 REAR 1992 1/2-93 1/2 E-350 CHASSIS - DRW - ABS - 70U
    605569 FORD 60 REAR 1993-95 E-250 VAN SRW - SEMI FLOAT
    605575 GM 80 REAR 1993-93 1/2 GMT 455 - 80
    605578 FORD 70 REAR 1992 1/2-93 1/2 E-350 SRW CUTAWAY, WIDE TRACK 70 2U
    605579 JEEP 35 REAR 1993-94 XJ UTILITY ABS
    605583 FORD 70 REAR 1992 1/2-93 1/2 CONTINENTAL BAKERY CHASSIS - ABS - 70U
    605584 FORD 70 REAR 1992 1/2-93 1/2 UPS CHASSIS - ABS - 70U
    605585 CHRY 60 REAR 1994-95 1/2 D2500
    605586 CHRY 60 REAR 1994-95 1/2 W2500
    605588 CHRY 70 REAR 1994-95 1/2 W2500
    605590 CHRY 70 REAR 1994-95 1/2 D2500
    605592 CHRY 80 REAR 1994-95 1/2 D3500
    605593 CHRY 80 REAR 1994-95 1/2 D3500
    605594 CHRY 80 REAR 1994-95 1/2 D/W3500
    605595 CHRY 80 REAR 1994-95 1/2 D2500
    605596 CHRY 80 REAR 1994-95 1/2 W2500
    605601 GM 80 REAR 1993-96 1/2 MOTOR HOME/DISC BRAKES - 80
    605602 JEEP 35 REAR 1994 ZJ ABS
    605607 JEEP 35 REAR 1994 ZJ ABS
    605608 FORD 70 REAR 1993 1/2-94 E-350 CHASSIS - DRW - ABS - 70U
    605609 FORD 70 REAR 1993 1/2-94 E-350 MOTOR HOME - ABS - 70HD
    605623 FORD 60 REAR 1993-94 E-250 VAN SRW - SEMI FLOAT - ABS
    605624 FORD 60 REAR 1993 1/2-94 E-350 VAN SRW - FULL FLOAT
    605632 FORD 80 REAR 1993-94 1/2 F-450 CHASSIS-DRW-FULL FLOAT
    605633 CHRY 60 REAR 1994-95 1/2 D2500
    605634 CHRY 60 REAR 1994-95 1/2 W2500
    605638 GM 80 REAR 1994-95 1/2 W2500
    605638 GM 80 REAR 1994 1/2-95 1/2 P-TRUCK - 80
    605639 FORD 60 REAR 1994-95 E-350 VAN SRW - FULL FLOAT
    605640 FORD 70 REAR 1994-94 1/2 E-350 CHASSIS - 70U
    605643 GM 80 REAR 1993 1/2-95 1/2 P-TRUCK - 80
    605644 GM 80 REAR 1993-95 1/2 P-TRUCK - 80
    605648 CHRY 44 REAR 1994-95 1/2 VIPER
    605649 GM 80 REAR 1995-95 1/2 GMT 455 - 80
    605655 JEEP 35 REAR 1994 XJ UTILITY, STD
    605656 JEEP 35 REAR 1994 XJ UTILITY
    605657 JEEP 35 REAR 1994 XJ UTILITY ABS
    605658 JEEP 35 REAR 1994 XJ UTILITY ABS
    605659 JEEP 35 REAR 1994 XJ UTILITY ABS
    605660 JEEP 35 REAR 1994 XJ UTILITY
    605661 JEEP 35 REAR 1994-96 YJ/TJ
    605662 JEEP 35 REAR 1994-96 YJ/TJ ABS
    605665 FORD 70 REAR 1993 1/2-94 E-350 CHASSIS - DRW - ABS - 70U
    605666 FORD 70 REAR 1993 1/2-94 E-350 CHASSIS - DRW - ABS - 70U
    605667 FORD 70 REAR 1993 1/2-94 1/2 E-350 CHASSIS - DRW - ABS - 70U
    605669 FORD 70 REAR 1993 1/2-94 E-350 SRW CUTAWAY, WIDE TRACK 70 2U
    605670 FORD 60 REAR 1994-94 1/2 E-350 VAN SRW - FULL FLOAT
    605671 FORD 70 REAR 1994 E-350 CHASSIS - DRW - ABS - 70U
    605672 FORD 70 REAR 1994-94 1/2 E-350 MOTOR HOME - ABS - 70HD
    605673 FORD 70 REAR 1994-94 1/2 E-350 CHASSIS - DRW - ABS - 70U
    605674 FORD 70 REAR 1994-94 1/2 E-350 SRW CUTAWAY, WIDETRACK 70 2U
    605675 FORD 70 REAR 1994-94 1/2 E-350 SRW CUTAWAY, WIDETRACK 70 2U
    605684 FORD 60 REAR 1995-96 E-350 VAN SRW - FULL FLOAT
    605685 FORD 60 REAR 1995-96 E-350 VAN SRW - FULL FLOAT
    605686 FORD 70 REAR 1995-95 1/2 E-350 SRW CUTAWAY, WIDE TRACK 70 2U
    605687 FORD 70 REAR 1995-95 1/2 E-350 CHASSIS - DRW - 70U
    605688 FORD 70 REAR 1995-95 1/2 E-350 MOTOR HOME - 70HD
    605689 FORD 70 REAR 1995-95 1/2 E-350 CHASSIS - DRW - 70U
    605690 FORD 70 REAR 1995-95 1/2 E-350 MOTOR HOME - ABS - 70HD
    605691 GM 80 REAR 1995-95 1/2 GMT 455 - 80
    605692 FORD 70 REAR 1994 E-350 CHASSIS - DRW - 70HD
    605693 FORD 70 REAR 1994 E-350 CHASSIS - DRW - 70HD
    605695 GM 80 REAR 1994 1/2-95 1/2 GMT 455 - 80
    605700 FORD 60 REAR 1995-96 E-350 VAN SRW - SEMI FLOAT - ABS
    605706 JEEP 35 REAR 1995-96 ZJ ABS
    605707 JEEP 35 REAR 1995-96 ZJ ABS
    605710 CHRY 60 REAR 1994 1/2-97 1/2 B-300 VAN W/ABS
    605711 CHRY 60 REAR 1994 1/2-97 1/2 B-300 VAN W/ABS
    605712 GM 80 REAR 1994 1/2-95 1/2 P-TRUCK - 80
    605713 FORD 60 REAR 1994 1/2 E-350 VAN SRW - FULL FLOAT - ABS
    605714 FORD 70 REAR 1994 1/2-95 E-350 CHASSIS - DRW - 70HD
    605715 FORD 70 REAR 1994 1/2-95 1/2 E-350 MOTOR HOME - ABS - 70HD
    605717 FORD 80 REAR 1995-95 1/2 F-450 CHASSIS-DRW-FULL FLOAT
    605718 CHRY 80 REAR 1995-97 SWEPTLINE VEHICLE
    605719 GM 80 REAR 1995-95 1/2 MOTOR HOME/DISC BRAKES - 80
    605722 CHRY 70 REAR 1995-95 1/2 AIR FORCE TOW VEHICLE W/ABS
    605723 CHRY 70 REAR 1995-95 1/2 D2500 AIR FORCE TOW VEHICLE ABS
    605725 JEEP 35 REAR 1994 XJ UTILITY ABS (NEW MODEL NUMBER 194)
    605727 JEEP 35 REAR 19950-96 1/2 XJ UTILITY ABS
    605728 JEEP 35 REAR 1995-96 XJ UTILITY, STD
    605729 JEEP 35 REAR 1995-96 XJ UTILITY
    605730 JEEP 35 REAR 1995-96 1/2 XJ UTILITY ABS
    605731 JEEP 35 REAR 1995-96 XJ UTILITY ABS
    605732 JEEP 35 REAR 1995-96 1/2 XJ UTILITY ABS
    605733 JEEP 35 REAR 1995-96 1/2 XJ UTILITY
    605735 JEEP 44 REAR 1996-97 ZJ ABS
    605745 GM 80 REAR 1994 1/2-95 1/2 P-TRUCK - 80
    605746 JEEP 35 REAR 1996 1/2 YJ/TJ ABS
    605747 JEEP 35 REAR 1996 1/2 YJ/TJ (NEW MODEL NUMBER 194)
    605750 FORD 60 REAR 1995-97 E-250 VAN SRW - SEMI FLOAT - ABS
    605752 CHRY 44 REAR 1996-97 VIPER
    605753 GM 80 REAR 1995 1/2-95 1/2 GMT 455 - 80
    605767 GM 80 REAR 1995-95 1/2 P-TRUCK - 80
    605775 JEEP 35 REAR 1996-96 1/2 XJ DIESEL
    605776 JEEP 35 REAR 1996-96 1/2 XJ DIESEL
    605783 GM 80 REAR 1995-95 1/2 P-TRUCK - 80
    605784 CHRY 60 REAR 1996-96 1/2 D2500
    605787 CHRY 70 REAR 1996-96 1/2 D2500
    605788 CHRY 80 REAR 1996-96 1/2 D3500
    605789 CHRY 80 REAR 1996-96 1/2 D3500
    605790 CHRY 80 REAR 1996-96 1/2 D/W3500
    605791 CHRY 80 REAR 1996-96 1/2 D2500
    605792 CHRY 80 REAR 1996 1/2 D2500
    605793 CHRY 60 REAR 1996-96 1/2 D2500
    605794 CHRY 60 REAR 1996 1/2 W2500
    605797 JEEP 35 REAR 1996 1/2-97 ZJ ABS (NEW MODEL NUMBER 194)
    605798 JEEP 35 REAR 1996 1/2-97 ZJ ABS (NEW MODEL NUMBER 194)
    605807 FORD 80 REAR 1997-98 E-350 DRW CHASSIS - FULL FLOAT
    605810 GM 80 REAR 1996-96 1/2 P-TRUCK - 80
    605811 GM 80 REAR 1996-96 1/2 P-TRUCK - 80
    605812 GM 80 REAR 1996-98 P-TRUCK - 80
    605813 GM 80 REAR 1996 1/2 P-TRUCK - 80
    605814 GM 80 REAR 1996-98 P-TRUCK - 80
    605815 GM 80 REAR 1996-98 P-TRUCK - 80
    605816 GM 80 REAR 1996-98 P-TRUCK - 80
    605817 GM 80 REAR 1996-96 1/2 P-TRUCK - 80
    605818 GM 80 REAR 1996-96 1/2 P-TRUCK - 80
    605831 FORD 80 REAR 1996-98 F-450 CHASSIS-DRW-FULL FLOAT
    605834 FORD 80 REAR 1996 E-350 DRW CHASSIS - FULL FLOAT
    605838 GM 80 REAR 1996 1/2-97 P-TRUCK - 80
    605839 GM 80 REAR 1996 1/2-97 P-TRUCK - 80
    605840 GM 80 REAR 1996 1/2-97 P-TRUCK - 80
    605841 FORD 60 REAR 1996-96 1/2 E-250 VAN SRW - SEMI FLOAT - ABS
    605842 FORD 60 REAR 1996-96 1/2 E-350 VAN SRW - FULL FLOAT
    605843 FORD 60 REAR 1996 E-350 VAN SRW - FULL FLOAT - ABS
    605844 FORD 70 REAR 1995-95 1/2 E-350 SRW CUTAWAY, WIDE TRACK 70 2U
    605845 FORD 70 REAR 1995-95 1/2 E-350 CHASSIS - DRW - 70U
    605846 FORD 70 REAR 1996-97 E-350 MOTOR HOME - ABS - 70HD
    605847 FORD 70 REAR 1996-97 E-350 CHASSIS - DRW - ABS - 70U
    605848 FORD 70 REAR 1996-97 E-350 MOTOR HOME - ABS - 70HD
    605849 JEEP 44 REAR 1997 TJ NON ABS (NEW MODEL NUMBER 216)
    605858 GM 80 REAR 1996 1/2 GMT 455 - 80
    605859 FORD 60 REAR 1996-97 E-250 VAN SRW - SEMI FLOAT - ABS
    605860 FORD 70 REAR 1996-97 E-350 CHASSIS - DRW - ABS - 70U
    605861 FORD 70 REAR 1996-97 E-650 CHASSIS - DRW - ABS - 70U
    605862 FORD 70 REAR 1996-97 E-350 CHASSIS - DRW - ABS - 70U
    605867 GM 80 REAR 1996-99 GMT 455 - 80
    605868 GM 80 REAR 1996-98 GMT 455 - 80
    605869 GM 80 REAR 1996-98 GMT 455 - 80
    605879 CHRY 70 REAR 1996-97 1/2 W2500 AIR FORCE TOW VEHICLE ABS
    605880 CHRY 70 REAR 1996-97 1/2 W2500 AIR FORCE TOW VEHICLE ABS
    605893 JEEP 35 REAR 1996 1/2 XJ UTILITY, STD (NEW MODEL NUMBER 194)
    605894 JEEP 35 REAR 1996 1/2 XJ UTILITY (NEW MODEL NUMBER 194)
    605895 JEEP 35 REAR 1996 1/2 XJ UTILITY ABS (NEW MODEL NUMBER 194)
    605896 GM 80 REAR 1996 1/2-97 P-TRUCK - 80
    605898 CHRY 60 REAR 1997-97 1/2 D2500
    605902 CHRY 80 REAR 1997 D3500
    605903 CHRY 80 REAR 1997 D3500
    605904 CHRY 80 REAR 1997 D/W3500
    605905 CHRY 80 REAR 1997 D2500
    605906 CHRY 80 REAR 1997 D2500
    605907 CHRY 60 REAR 1997-97 1/2 D2500
    605908 CHRY 60 REAR 1997-97 1/2 W2500
    605909 JEEP 35 REAR 1996 1/2 XJ DIESEL, ABS (NEW MODEL NUMBER 194)
    605913 JEEP 35 REAR 1997 XJ UTILITY ABS (NEW MODEL NUMBER 194)
    605914 JEEP 35 REAR 1997 XJ UTILITY ABS (NEW MODEL NUMBER 194)
    605916 JEEP 35 REAR 1997 XJ DIESEL, NON ABS (NEW MODEL NUMBER 194)
    605918 JEEP 35 REAR 1997 XJ UTILITY, ABS (NEW MODEL NUMBER 194)
    605919 JEEP 35 REAR 1997 XJ DIESEL ABS (NEW MODEL NUMBER 194)
    605924 FORD 80 REAR 1998 1/2-99 F-350 CHASSIS-DRW-FULL FLOAT
    605925 FORD 80 REAR 1998 1/2-99 F-450 CHASSIS-DRW-FULL FLOAT
    605926 FORD 80 REAR 1998 1/2-99 F-350 PICK-UP DRW-FULL FLOAT
    605933 FORD 60 REAR 1996 1/2-97 E-250 VAN SRW - SEMI FLOAT
    605934 FORD 60 REAR 1996 1/2 E-350 VAN SRW - FULL FLOAT
    605935 FORD 60 REAR 1996 1/2 E-350 VAN SRW - FULL FLOAT
    605942 FORD 80 REAR 1998 1/2-99 F-350 CHASSIS-DRW-FULL FLOAT
    605944 FORD 80 REAR 199 1/2 F-450 MOTOR HOME - DRW - FULL FLOAT
    605947 FORD 60 REAR 1997 1/2 E-250 VAN SRW - SEMI FLOAT - ABS
    605948 FORD 60 REAR 1997 1/2 E-350 VAN SRW - FULL FLOAT
    605949 FORD 60 REAR 1997 1/2 E-350 VAN SRW - FULL FLOAT
    605950 FORD 70 REAR 1997 E-350 SRW CUTAWAY, WIDE TRACK 70 2U
    605951 FORD 70 REAR 1997 E-350 CHASSIS - DRW - ABS - 70U
    605952 JEEP 44 REAR 1997 TJ RHD, NON ABS (NEW MODEL NUMBER 216)
    605956 JEEP 35 REAR 1997 TJ ABS (NEW MODEL NUMBER 194)
    605957 JEEP 35 REAR 1997 TJ NON ABS (NEW MODEL NUMBER 194)
    605960 JEEP 35 REAR 1997 ZJ ABS (NEW MODEL NUMBER 194)
    605961 JEEP 35 REAR 1997 ZJ ABS (NEW MODEL NUMBER 194)
    605962 JEEP 44 REAR 1997 ZJ ABS (NEW MODEL NUMBER 216)
    605975 CHRY 80 REAR 1997 1/2 D3500
    605976 CHRY 80 REAR 1997 1/2 D3500
    605977 CHRY 80 REAR 1997 1/2 D/W3500
    605978 CHRY 60 REAR 1998-98 1/2 D2500
    605982 CHRY 80 REAR 1998-98 1/2 D3500
    605983 CHRY 80 REAR 1998-98 1/2 D3500
    605984 CHRY 80 REAR 1998-98 1/2 D/W3500
    605985 CHRY 80 REAR 1998-98 1/2 D2500
    605987 CHRY 60 REAR 1998-98 1/2 D2500
    605988 CHRY 60 REAR 1998-98 1/2 W2500
    606014 CHRY 44 REAR 1998-98 1/2 VIPER
    606017 FORD 60 REAR 1998-98 1/2 E-250 VAN SRW - SEMI FLOAT - ABS
    606020 FORD 70 REAR 1998-98 1/2 E-350 SRW CUTAWAY, WIDE TRACK 70U
    606021 FORD 70 REAR 1998-98 1/2 E-350 CHASSIS - DRW - ABS - 70U
    606022 FORD 60 REAR 1999 E-350 VAN SRW - SEMI FLOAT - ABS
    606026 FORD 70 REAR 1999 E-350 CUTAWAY SRW OR CHASSIS DRW OPTION
    606028 FORD 70 REAR 1997 1/2-98 1/2 E-350 CHASSIS - DRW
    606029 FORD 60 REAR 1997 1/2-98 E-250 VAN SRW - SEMI FLOAT - ABS
    606040 GM 80 REAR 1997-99 P-TRUCK - 80
    606041 GM 80 REAR 1997-99 P-TRUCK - 80
    606042 GM 80 REAR 1997-99 P-TRUCK - 80
    606043 GM 80 REAR 1997-99 P-TRUCK - 80
    606049 FORD 60 REAR 1998 E-350 VAN SRW - FULL FLOAT - ABS
    606050 FORD 60 REAR 1998 E-350 VAN SRW - FULL FLOAT - ABS
    606054 CHRY 60 REAR 1997 1/2 W2500
    606056 CHRY 80 REAR 1997 1/2 W2500
    606058 CHRY 60 REAR 1998-98 1/2 B-300 VAN W/ABS
    606059 CHRY 60 REAR 1998-98 1/2 B-300 VAN W/ABS
    606062 CHRY 60 REAR 1998-98 1/2 W2500
    606064 CHRY 80 REAR 1998-98 1/2 W2500
    606073 GM 80 REAR 1998 1/2-99 GMT 455 - 80
    606074 GM 80 REAR 1998 1/2-99 GMT 455 - 80
    606076 FORD 80 REAR 1998 1/2 E-350 SUPER DUTY - DRW - FULL FLOAT
    606102 FORD 60 REAR 1998 1/2-99 E-250 VAN SRW - SEMI FLOAT - ABS
    606109 FORD 60 REAR 1999 E-350 VAN SRW - FULL FLOAT - ABS
    606123 GM 80 REAR 1998 1/2-99 GMT 455 - 80
    606144 FORD 80 REAR 1999 E-350 SUPER DUTY - DRW - FULL FLOAT
    606145 FORD 70 REAR 1999-99 1/2 E-350 CHASSIS - DRW
    606158 FORD 70 REAR 1998 1/2-99 E-350 CUTAWAY OR CHASSIS DRW OPTION
    606159 FORD 70 REAR 1998 1/2 E-350 DRW CHASSIS - FULL FLOAT
    606161 FORD 60 REAR 1998 1/2-99 E-250 VAN SRW - SEMI FLOAT - ABS
    606162 FORD 60 REAR 1998 1/2-99 E350 VAN SRW - FULL FLOAT - ABS
    606188 FORD 60 REAR 1999 1/2 E-250 VAN SRW
    606189 FORD 70 REAR 1999 1/2 E-350 CUTAWAY SRW OR CHASSIS DRW OPTION
    606192 FORD 60 REAR 1999 1/2 E-250 VAN SRW
    606199 FORD 60 REAR 1999-99 1/2 E-350 CHASSIS - DRW
    606201 GM 80 REAR 1999 1/2 P-TRUCK - 80
    606202 GM 80 REAR 1999 1/2 P-TRUCK - 80
    606203 GM 80 REAR 1999 1/2 P-TRUCK - 80
    606204 GM 80 REAR 1999 1/2 P-TRUCK - 80 WIDETRACK
    606211 GM 80 REAR 1999 1/2 GMT 455 - 80
    606212 GM 80 REAR 1999 1/2 GMT 455 - 80 WIDETRACK
    606213 GM 80 REAR 1999 1/2 GMT 455 - 80
    606214 GM 80 REAR 1999 1/2 GMT 455 - 80
    610023 FORD 60 FRONT 1978-79 F-250 & F-350 (SNOW FIGHTER)
    610027 CHRY 44 FRONT 1979 W-100
    610028 CHRY 44 FRONT 1979 W-200
    610053 JEEP 30 FRONT 1979 CJ5/CJ7 - EXTERNAL TYPE WHEEL END
    610054 GM 44 FRONT 1979 BLAZER & K-10
    610055 GM 44 FRONT 1978-79 K-20
    610056 GM 44 FRONT 1979 K-20
    610057 GM 60 FRONT 1979-80 K-30
    610062 FORD 44 FRONT 1980 BRONCO II & F-150 PICK-UP WITH PART TIME TRANSFER CASE
    610063 FORD 44 FRONT 1980 F-250 3/4-TON PICK-UP (PART TIME TRANSFER CASE)
    610064 FORD 50 FRONT 1980 F-350
    610066 FORD 44 FRONT 1979 F-150 1/2 TON PICK-UP (FULL TIME TRANSFER CASE)
    610067 FORD 44 FRONT 1979 F-150 1/2 TON PICK-UP (PART TIME TRANSFER CASE)
    610068 FORD 44 FRONT 1979 F-150 SUPER CAB
    610069 FORD 44 FRONT 1979 F-250
    610076 CHRY 44 FRONT 1980 W-100
    610077 CHRY 44 FRONT 1980 W-200
    610078 JEEP 30 FRONT 1980-81 IFS - EAGLE - NON-DISCONNECT
    610079 GM 44 FRONT 1980 K-20
    610080 GM 44 FRONT 1979-80 K-20
    610081 GM 44 FRONT 1979-80 K-20
    610084 CHRY 44 FRONT 1980-83 W-200
    610086 JEEP 30 FRONT 1980 CJ5/CJ7 - EXTERNAL TYPE WHEEL END
    610089 JEEP 44 FRONT 1980 J10, J20, WIDE TRACK CHEROKEE
    610090 JEEP 44 FRONT 1980 WAGONEER / CHEROKEE
    610127 CHRY 44 FRONT 1981-84 W-100
    610128 CHRY 44 FRONT 1981-84 W-200
    610132 GM 60 FRONT 1981 K-30
    610134 JEEP 30 FRONT 1981 IFS - EAGLE - DISCONNECT
    610135 CHRY 60 FRONT 1981-85 D-600 & D-700
    610136 JEEP 30 FRONT 1981 CJ5/CJ7 - EXTERNAL TYPE WHEEL END
    610139 JEEP 44 FRONT 1981-85 J10, J20, WIDETRACK CHEROKEE
    610140 JEEP 44 FRONT 1981-85 WAGONEER / CHEROKEE
    610146 FORD 44 FRONT 1981 F-250 & F-350 HD
    610147 FORD 50 FRONT 19818-82 F-250 & F-350 (SNOW FIGHTER)
    610152 JEEP 30 FRONT 1982-82 1/2 IFS - EAGLE - NON DISCONNECT
    610153 JEEP 30 FRONT 1982-82 1/2 IFS - EAGLE - DISCONNECT
    610154 JEEP 30 FRONT 1981 1/2 CJ5/CJ7 - EXTERNAL TYPE WHEEL END
    610156 JEEP 30 FRONT 1982-83 CJ5 - EXTERNAL TYPE WHEEL END
    610157 JEEP 44 FRONT 1982-84 WAGONEER, CHEROKEE DISCONNECT STD TRACK
    610158 JEEP 44 FRONT 1982-84 J10, J20, WIDE TRACK CHEROKEE
    610159 GM 60 FRONT 1982-87 K-30
    610160 CHRY 44 FRONT 1985-89 D-600 (EXPORT)
    610164 JEEP 30 FRONT 1982-87 CJ7/CJ8 - EXTERNAL TYPE WHEEL END
    610166 FORD 44 FRONT 1981 1/2-82 F-150 SNOW PLOW
    610167 FORD 44 FRONT 1983 F-150 SNOW PLOW
    610168 FORD 44 FRONT 1983 BRONCO & F-150
    610169 FORD 44 FRONT 1983 F-250 & F-350 HD
    610170 FORD 50 FRONT 1983 F-350
    610171 FORD 28 FRONT 1983-84 RANGER
    610172 JEEP 30 FRONT 1984 XJ DISCONNECT, CV
    610173 JEEP 30 FRONT 1983-84 IFS - EAGLE - NON-DISCONNECT
    610174 JEEP 30 FRONT 1983-84 IFS - EAGLE - DISCONNECT
    610175 JEEP 30 FRONT 1984-87 XJ DISCONNECT, CARDAN
    610177 FORD 44 FRONT 1984 F-150 SNOW PLOW
    610178 FORD 44 FRONT 1984 BRONCO & F-150
    610179 FORD 44 FRONT 1984 F-250 & F-350 HD
    610180 FORD 50 FRONT 1984 F-250 & F-350 (SNOW FIGHTER)
    610182 JEEP 30 FRONT 1984-85 XJ DISCONNECT, CARDAN, SYSTEM SENTRY
    610183 JEEP 30 FRONT 1985-87 XJ NON-DISCONNECT, CARDAN - LIVE SPINDLE WHEEL END
    610185 FORD 44 FRONT 1981-82 BRONCO II & F-150
    610197 FORD 44 FRONT 1984 1/2-85 F-150 SNOW PLOW
    610198 FORD 44 FRONT 1984 1/2-85 BRONCO&F-150
    610199 FORD 44 FRONT 1984 1/2-85 F-250
    610200 FORD 50 FRONT 1984 1/2 F-250 & F-350 (SNOW FIGHTER)
    610201 GM 60 FRONT 1984-88 CUCV
    610202 GM 60 FRONT 1984-85 K-30
    610206 JEEP 30 FRONT 1985 XJ NON-DISCONNECT, CARDAN - LIVE SPINDLE WHEEL END
    610216 CHRY 44 FRONT 1985-86 D-500 & D-800
    610217 CHRY 44 FRONT 1985-86 D-600
    610220 FORD 60 FRONT 1985 F-350
    610221 JEEP 30 FRONT 1985 XJ NON-DISCONNECT, CV, SYSTEM SENTRY - LIVE SPINDLE WHEEL END
    610222 JEEP 30 FRONT 1985-86 XJ NON-DISCONNECT, CV - LIVE SPINDLE WHEEL END
    610223 FORD 28 FRONT 1984 1/2-85 RANGER/BRONCO II
    610227 JEEP 44 FRONT 1985 GRAND WAGONEER
    610228 JEEP 44 FRONT 1985 4X2, MILITARY - DEAD FRONT
    610229 FORD 44 FRONT 1985 F-250
    610230 FORD 50 FRONT 1985 F-250 & F-350 (SNOW FIGHTER)
    610231 FORD 44 FRONT 1985 F-250 & F-350 HD
    610232 FORD 50 FRONT 1985 1/2 F-350
    610234 JEEP 30 FRONT 1985-86 XJ 4X2, SYSTEM SENTRY (DEAD FRONT)
    610235 JEEP 30 FRONT 1985-87 1/2 IFS - EAGLE - NON-DISCONNECT - CV
    610236 CHRY 60 FRONT 1985-88 D-600 & D-700
    610237 JEEP 30 FRONT 1985 XJ 4X2, SYSTEM SENTRY (DEAD FRONT)
    610241 FORD 44 FRONT 1985 1/2 BRONCO & F-150
    610242 FORD 44 FRONT 1985 1/2 F-150 SNOW PLOW
    610243 FORD 44 FRONT 1985 1/2 F-250
    610244 JEEP 30 FRONT 1986 CJ7, LH STEERING, H/L - EXTERNAL TYPE WHEEL END
    610246 JEEP 44 FRONT 1986 J10 PICKUP
    610247 JEEP 44 FRONT 1986 GRAND WAGONEER
    610248 JEEP 44 FRONT 1986 J20
    610249 FORD 28 FRONT 1986-87 RANGER/BRONCO II
    610254 FORD 50 FRONT 1986-87 F-250 & F-350 (SNOW FIGHTER)
    610255 FORD 60 FRONT 1986-88 F-350 MONOBEAM DRW
    610256 JEEP 30 FRONT 1986-89 XJ 4X2 (DEAD FRONT)
    610257 CHRY 44 FRONT 1986 1/2-87 1/2 D-500 & D-800
    610258 CHRY 44 FRONT 1986-87 1/2 D-600
    610259 JEEP 30 FRONT 1986 YJ DISCONNECT
    610261 FORD 44 FRONT 1986 BRONCO & F-150
    610262 FORD 44 FRONT 1986 BRONCO & F-150
    610263 FORD 44 FRONT 1986 F-150 SNOW PLOW
    610264 FORD 44 FRONT 1986-87 F-250
    610265 CHRY 61 FRONT 1987-88 D-600 & D-700
    610266 FORD 44 FRONT 1987-88 F-150 SNOW PLOW
    610267 FORD 44 FRONT 1987-88 BRONCO & F-150
    610268 FORD 44 FRONT 1987-88 BRONCO & F-150
    610269 JEEP 30 FRONT 1986 YJ NON-DISCONNECT - LIVE SPINDLE WHEEL END
    610270 CHRY 44 FRONT 1992-93 1/2 D-600 & D-800
    610271 CHRY 44 FRONT 1992-93 1/2 D-600
    610277 CHRY 44 FRONT 1988-88 1/2 D-500 & D-800
    610278 CHRY 44 FRONT 1988-88 1/2 D-600
    610279 JEEP 30 FRONT 1987 1/2-88 XJ DISCONNECT
    610280 JEEP 30 FRONT 1987 1/2-88 XJ NON-DISCONNECT - LIVE SPINDLE WHEEL END
    610281 JEEP 30 FRONT 1987-88 YJ DISCONNECT
    610282 JEEP 30 FRONT 1987-88 YJ NON-DISCONNECT - LIVE SPINDLE WHEEL END
    610283 JEEP 44 FRONT 1987-88 GRAND WAGONEER
    610284 JEEP 44 FRONT 1987-87 1/2 J10
    610285 JEEP 44 FRONT 1987-87 1/2 J20
    610294 JEEP 30 FRONT 1987 1/2-88 XJ NON-DISCONNECT, ABS, ANTI SKID - LIVE SPINDLE WHEEL END
    610295 GM 60 FRONT 1988-91 1/2 V-30
    610297 JEEP 30 FRONT 1988 XJ DISCONNECT, VALEO EXPORT
    610298 FORD 28 FRONT 1987 1/2 RANGER/BRONCO II
    610300 FORD 35 FRONT 1990 RANGER/BRONCO II
    610303 FORD 28 FRONT 1990-92 AEROSTAR
    610304 FORD 50 FRONT 1988-88 1/2 F-250 & F-350 (SNOW FIGHTER)
    610305 FORD 60 FRONT 1988 F-350 MONOBEAM SRW
    610306 FORD 44 FRONT 1988 F-250
    610307 FORD 28 FRONT 1988-89 RANGER/BRONCO II
    610309 FORD 44 FRONT 1988 1/2 F-150 SNOW PLOW, BRONCO
    610310 FORD 44 FRONT 1988 1/2-92 BRONCO & F-150
    610311 FORD 44 FRONT 1988 1/2-91 BRONCO & F-150
    610312 FORD 50 FRONT 1989-92 1/2 F-250 & F-350 (SNOW FIGHTER)
    610313 FORD 60 FRONT 1988 1/2-91 1/2 F-350 MONOBEAM SRW
    610316 JEEP 30 FRONT 1992 1/2-93 1/2 XJ 4X2 (DEAD FRONT)
    610317 JEEP 30 FRONT 1990-90 1/2 XJ DISCONNECT
    610318 JEEP 30 FRONT 1990-91 1/2 XJ NON-DISCONNECT - LIVE SPINDLE WHEEL END
    610319 JEEP 30 FRONT 1990-90 1/2 YJ DISCONNECT
    610320 JEEP 30 FRONT 1990-91 1/2 YJ NON-DISCONNECT - LIVE SPINDLE WHEEL END
    610321 JEEP 30 FRONT 1988 1/2-89 XJ DISCONNECT
    610322 JEEP 30 FRONT 1988 1/2-89 XJ NON-DISCONNECT - LIVE SPINDLE WHEEL END
    610323 JEEP 30 FRONT 1988 1/2-89 YJ DISCONNECT
    610324 JEEP 30 FRONT 1988 1/2-89 YJ NON-DISCONNECT - LIVE SPINDLE WHEEL END
    610325 JEEP 44 FRONT 1988 1/2-92 GRAND WAGONEER
    610327 JEEP 30 FRONT 1988 1/2-89 XJ NON-DISCONNECT, ABS, ANTISKID - LIVE SPINDLE WHEEL END
    610328 JEEP 30 FRONT 1988 1/2-89 XJ DISCONNECT, VALEO EXPORT
    610329 CHRY 44 FRONT 1988-88 1/2 D-500 & D-800
    610331 CHRY 44 FRONT 1989-90 D-600
    610332 CHRY 60 FRONT 1989 D-600 & D-700
    610333 CHRY 61 FRONT 1989 D-600 & D-700
    610334 JEEP 30 FRONT 1988 XJ NON-DISCONNECT, VALEO EXPORT - LIVE SPINDLE WHEEL END
    610335 FORD 44 FRONT 1988 1/2-92 BRONCO & F-150
    610336 JEEP 30 FRONT 1990-91 1/2 XJ NON-DISCONNECT, ABS - LIVE SPINDLE
    610337 JEEP 30 FRONT 1988 1/2-89 XJ NON-DISCONNECT, VALEO EXPORT - LIVE SPINDLE WHEEL END
    610339 JEEP 30 FRONT 1990-90 1/2 XJ DISCONNECT, VALEO EXPORT
    610340 JEEP 30 FRONT 1990-90 1/2 XJ NON-DISCONNECT, VALEO EXPORT - LIVE SPINDLE WHEEL END
    610341 CHRY 60 FRONT 1989-90 D-600
    610342 CHRY 61 FRONT 1989 D-600 & D-700
    610346 JEEP 30 FRONT 1992 1/2-93 ZJ ABS, CV JOINT
    610348 JEEP 30 FRONT 1992-93 1/2 XJ 4X2 (DEAD FRONT), ABS
    610351 JEEP 30 FRONT 1990 1/2-91 1/2 XJ 4X2 (DEAD FRONT)
    610355 CHRY 44 FRONT 1990-91 1/2 D-500 & D-800
    610356 CHRY 44 FRONT 1991-91 1/2 D-600
    610357 CHRY 60 FRONT 1991-91 1/2 D-600
    610358 CHRY 61 FRONT 1991-92 D-600 & D-700
    610360 CHRY 44 FRONT 1991-91 1/2 D-600
    610361 JEEP 30 FRONT 1991-91 1/2 XJ DISCONNECT
    610362 JEEP 30 FRONT 1991-91 1/2 YJ DISCONNECT
    610363 JEEP 30 FRONT 1991 XJ DISCONNECT
    610365 FORD 35 FRONT 1990 1/2-92 1/2 RANGER/BRONCO II
    610366 FORD 35 FRONT 1990 1/2-92 1/2 EXPLORER
    610367 JEEP 30 FRONT 1995-97 XJ NON-DISCONNECT, CARDAN - LIVE SPINDLE WHEEL END
    610369 FORD 28 FRONT 1992 1/2 AEROSTAR
    610371 FORD 60 FRONT 1992 F-350 (USES SOCKET ASSY INSTEAD OF KING PIN ASSY)
    610372 JEEP 30 FRONT 1991 XJ NON-DISCONNECT - LIVE SPINDLE WHEEL END
    610373 JEEP 30 FRONT 1991 XJ NON-DISCONNECT
    610374 JEEP 30 FRONT 1991 XJ NON-DISCONNECT, ABS
    610375 JEEP 30 FRONT 1991 XJ 4X2 (DEAD FRONT)
    610377 JEEP 30 FRONT 1992 1/2-93 ZJ ABS
    610379 JEEP 30 FRONT 1992-93 1/2 XJ NON-DISCONNECT, ABS
    610381 JEEP 30 FRONT 1993-93 1/2 YJ DOSCONNECT ABS
    610391 JEEP 30 FRONT 1992-93 1/2 XJ NON-DISCONNECT
    610392 JEEP 30 FRONT 1992-93 1/2 YJ NON-DISCONNECT
    610393 JEEP 30 FRONT 1992-93 1/2 YJ DISCONNECT
    610398 CHRY 60 FRONT 1992 D-600
    610400 JEEP 30 FRONT 1993 ZJ (DEAD FRONT), ABS
    610401 JEEP 30 FRONT 1991 1/2 XJ DISCONNECT
    610402 JEEP 30 FRONT 1991 1/2 XJ NON-DISCONNECT
    610403 JEEP 30 FRONT 1991 1/2 XJ NON-DISCONNECT, ABS
    610404 JEEP 30 FRONT 1991 1/2-92 1/2 XJ 4X2 (DEAD FRONT)
    610405 CHRY 60 FRONT 1993 D-600 & D-700
    610406 CHRY 61 FRONT 1993-93 1/2 D-600 & D-700
    610407 FORD 44 FRONT 1992 1/2 BRONCO & F-150
    610408 FORD 44 FRONT 1992 1/2 BRONCO & F-150
    610410 FORD 35 FRONT 1993-94 1/2 EXPLORER ABS
    610411 FORD 44 FRONT 1993-93 1/2 BRONCO ABS
    610414 FORD 44 FRONT 1993-93 1/2 BRONCO & F-150
    610416 JEEP 30 FRONT 1993 XJ 4X2 (DEAD FRONT), ABS
    610417 JEEP 30 FRONT 1993-93 1/2 XJ NON-DISCONNECT, ABS
    610418 FORD 28 FRONT 1993-94 1/2 RANGER
    610419 FORD 35 FRONT 1993-94 1/2 RANGER
    610422 CHRY 44 FRONT 1994-94 1/2 W1500
    610423 CHRY 44 FRONT 1994-94 1/2 W2500
    610424 CHRY 44 FRONT 1994-94 1/2 W1500
    610425 CHRY 44 FRONT 1994-94 1/2 W2500
    610426 CHRY 60 FRONT 1994-94 1/2 W2500 HD
    610428 CHRY 60 FRONT 1994-94 1/2 W3500
    610430 CHRY 60 FRONT 1992-92 1/2 D-600 & D-700
    610431 CHRY 61 FRONT 1992-92 1/2 D-600 & D-700
    610432 FORD 60 FRONT 1993-93 1/2 F-350
    610436 FORD 35 FRONT 1992 1/2 RANGER
    610437 FORD 35 FRONT 1992 1/2 EXPLORER
    610438 JEEP 30 FRONT 1993 ZJ ABS, CV JOINT
    610439 FORD 50 FRONT 1993-94 F-250 & F-350 (SNOW FIGHTER)
    610440 CHRY 60 FRONT 1994-94 1/2 W2500 HD
    610443 FORD 44 FRONT 1994 BRONCO ABS
    610444 FORD 44 FRONT 1994 BRONCO & F-150
    610445 FORD 60 FRONT 1994 F-350
    610446 FORD 44 FRONT 1995 BRONCO & F-150
    610447 FORD 44 FRONT 1994 BRONCO ABS
    610448 FORD 28 FRONT 1992 1/2-97 AEROSTAR
    610449 JEEP 30 FRONT 1993 1/2 ZJ ABS
    610450 JEEP 30 FRONT 1993 1/2 ZJ ABS
    610451 JEEP 30 FRONT 1993 1/2 ZJ ABS
    610452 JEEP 30 FRONT 1993 1/2 ZJ (DEAD FRONT), ABS
    610459 FORD 50 FRONT 1995 F-250 & F-350 (SNOW FIGHTER)
    610460 FORD 60 FRONT 1995 F-350
    610461 JEEP 30 FRONT 1994-96 YJ DISCONNECT
    610462 JEEP 30 FRONT 1994-96 YJ DISCONNECT
    610463 JEEP 30 FRONT 1994-96 YJ NON-DISCONNECT
    610464 JEEP 30 FRONT 1994 YJ DISCONNECT
    610465 JEEP 30 FRONT 1994 ZJ (DEAD FRONT), ABS
    610466 JEEP 30 FRONT 1994 XJ NON-DISCONNECT
    610467 JEEP 30 FRONT 1994 XJ NON-DISCONNECT
    610473 JEEP 30 FRONT 1994-96 ZJ ABS
    610474 JEEP 30 FRONT 1994-94 1/2 ZJ ABS
    610475 JEEP 30 FRONT 1994-97 ZJ (DEAD FRONT), ABS
    610476 FORD 35 FRONT 1995 EXPLORER - DISCONNECT
    610478 JEEP 30 FRONT 1994-96 ZJ ABS
    610483 FORD 35 FRONT 1995-97 1/2 RANGER ABS
    610484 FORD 28 FRONT 1995-97 1/2 RANGER ABS
    610489 JEEP 30 FRONT 1997 TJ RHD, NON ABS (NEW MODEL NUMBER 181)
    610500 JEEP 30 FRONT 1994 1/2-96 XJ 4X2 (DEAD FRONT)
    610501 JEEP 30 FRONT 1994 1/2-97 XJ 4X2 (DEAD FRONT), ABS
    610502 JEEP 30 FRONT 1994 1/2-97 XJ NON-DISCONNECT
    610503 JEEP 30 FRONT 1994 1/2-97 XJ NON-DISCONNECT, ABS
    610504 JEEP 30 FRONT 1994 1/2-97 XJ RHD, (DEAD FRONT) NON ABS (NEW MODEL NUMBER 181)
    610505 JEEP 30 FRONT 1994 1/2-97 XJ RHD, ABS (NEW MODEL NUMBER 181)
    610506 JEEP 30 FRONT 1994 1/2-97 XJ RHD, (DEAD FRONT) NON ABS (NEW MODEL NUMBER 181)
    610507 JEEP 30 FRONT 1994 1/2-97 XJ RHD, (DEAD FRONT) NON ABS (NEW MODEL NUMBER 181)
    610512 CHRY 44 FRONT 1995-96 1/2 W1500
    610513 CHRY 44 FRONT 1995-96 1/2 W2500
    610514 CHRY 44 FRONT 1995 W1500
    610515 CHRY 44 FRONT 1995 W2500
    610517 CHRY 60 FRONT 1995-96 W3500
    610518 CHRY 60 FRONT 1995-96 W2500 HD
    610528 JEEP 30 FRONT 1995-97 XJ NON-DISCONNECT, ABS
    610532 CHRY 60 FRONT 1995-96 AIR FORCE TOW VEHICLE NON-ABS
    610537 CHRY 44 FRONT 1995-95 1/2 W1500
    610538 CHRY 44 FRONT 1995-95 1/2 W2500
    610539 CHRY 60 FRONT 1995-95 1/2 W2500 HD
    610540 CHRY 60 FRONT 1995-95 1/2 W3500
    610556 FORD 35 FRONT 1998 EXPLORER - NON DISCONNECT - CV
    610557 JEEP 30 FRONT 1995 1/2-97 XJ RHD, NON ABS (NEW MODEL NUMBER 181)
    610558 JEEP 30 FRONT 1995-97 XJ NON-DISCONNECT, ABS
    610572 JEEP 30 FRONT 1996 1/2-97 ZJ ABS (NEW MODEL NUMBER 181)
    610573 JEEP 30 FRONT 1996 1/2-97 ZJ ABS (NEW MODEL NUMBER 181)
    610576 CHRY 35 FRONT 1997-99 DAKOTA
    610581 FORD 35 FRONT 1995-96 EXPLORER - DISCONNECT - CV
    610582 FORD 35 FRONT 1995-96 EXPLORER - DISCONNECT
    610585 FORD 35 FRONT 1996 EXPLORER - NON DISCONNECT - CV
    610586 FORD 35 FRONT 1996 EXPLORER - NON DISCONNECT
    610602 CHRY 44 FRONT 1996 W1500
    610603 CHRY 44 FRONT 1996 W2500
    610604 CHRY 60 FRONT 1996 W2500 HD
    610605 CHRY 60 FRONT 1996 W3500
    610607 FORD 44 FRONT 1996 1/2 BRONCO & F-150
    610608 FORD 44 FRONT 1996 1/2 BRONCO ABS
    610609 FORD 50 FRONT 1996 1/2-97 F-250 & F-350 (SNOW FIGHTER)
    610610 FORD 60 FRONT 1996 1/2-97 F-350
    610612 CHRY 44 FRONT 1996 W1500
    610613 CHRY 44 FRONT 1996 W2500
    610614 CHRY 44 FRONT 1996 1/2 W1500
    610615 CHRY 44 FRONT 1996 1/2 W2500
    610616 CHRY 60 FRONT 1996 1/2 W2500 HD
    610617 CHRY 60 FRONT 1996 1/2 W2500 HD
    610618 CHRY 60 FRONT 1996 1/2 W3500
    610619 CHRY 60 FRONT 1996 1/2 W3500
    610622 CHRY 60 FRONT 1996 1/2 AIR FORCE TOW VEHICLE NON-ABS
    610629 JEEP 30 FRONT 1997 TJ ABS (NEW MODEL NUMBER 181)
    610630 JEEP 30 FRONT 1997 TJ
    610631 CHRY 44 FRONT 1997-97 1/2 W1500
    610632 CHRY 44 FRONT 1997-97 1/2 W2500
    610633 CHRY 44 FRONT 1997-97 1/2 W1500
    610634 CHRY 44 FRONT 1997-97 1/2 W2500
    610635 CHRY 60 FRONT 1997 W2500 HD
    610636 CHRY 60 FRONT 1997 W2500 HD
    610637 CHRY 60 FRONT 1997 W3500
    610638 CHRY 60 FRONT 1997 W3500
    610642 FORD 35 FRONT 1998-98 1/2 EXPLORER - NON-DISCONNECT - CV
    610643 FORD 35 FRONT 1998-98 1/2 EXPLORER - NON-DISCONNECT
    610644 FORD 35 FRONT 1997 1/2 EXPLORER - NON-DISCONNECT - CV
    610645 FORD 35 FRONT 1998-98 1/2 EXPLORER - NON-DISCONNECT
    610652 FORD 35 FRONT 1997-97 1/2 RANGER
    610653 FORD 28 FRONT 1997 RANGER NON ABS
    610654 FORD 50 FRONT 1998 1/2-99 F-250/350 SRW ABS
    610659 FORD 50 FRONT 1998 1/2-99 F-250/350 SRW NON-ABS
    610663 JEEP 30 FRONT 1997 ZJ ABS (NEW MODEL NUMBER 181)
    610664 JEEP 30 FRONT 1997 ZJ ABS (NEW MODEL NUMBER 181)
    610665 JEEP 30 FRONT 1997 ZJ (DEAD FRONT), ABS (NEW MODEL NUMBER 181)
    610714 CHRY 60 FRONT 1997 1/2 AIR FORCE TOW VEHICLE NON-ABS
    610715 CHRY 44 FRONT 1998-98 1/2 W1500
    610717 CHRY 44 FRONT 1998-98 1/2 W1500
    610719 CHRY 60 FRONT 1998-98 1/2 W2500 HD
    610720 CHRY 60 FRONT 1998-98 1/2 W3500
    610722 CHRY 60 FRONT 1998-98 1/2 W3500
    610723 CHRY 60 FRONT 1998-98 1/2 W3500
    610729 CHRY 60 FRONT 1997 1/2 W3500
    610730 CHRY 60 FRONT 1997 1/2 W3500
    610738 CHRY 60 FRONT 1997 1/2 W200 HD
    610739 CHRY 60 FRONT 1997 1/2 W2500 HD
    610740 FORD 50 FRONT 1997 1/2-98 F-250 & F-350 (SNOW FIGHTER)
    610741 FORD 60 FRONT 1997 1/2-98 F-350
    610774 FORD 35 FRONT 1999 EXPLORER - NON-DISCONNECT - CV
    610892 FORD 50 FRONT 1999 1/2-2000 F-250/350 SRW NON-ABS
    610893 FORD 50 FRONT 1999 1/2-2000 F-250/350 SRW ABS
    Nov 2003
    Atlanta, GA
    2,386
    There is a page on www.pirate4X4.com under the forum section somewhere that has a COMPLETE dana 60 tech page. I just simply "borrowed" all fo the information that I needed. I can't remember the address, but it is super cool. Too bad its on a turd of a website.
    Jack
