Keep your AMC V8 Alive (message for oil pump rebuilding)
Thread: Keep your AMC V8 Alive (message for oil pump rebuilding)
    A Hint Here:
    I have 5 timing covers here from various years all need MAJOR fixing due to customers installing NEW* oil gear sets and not watching for burrs on the drive gear's shaft where the slot was put in, here is a pic of where the burr is....DO NOT FORCE YOUR GEARS INTO THE COVER! This gouges the cover and oil is pumped up through the hole the shaft goes into and starves the WHOLE MOTOR of oil. Be carefull out there guys
    Sep 2003
    Oak Harbor, WA 98277
    634
    Word on the street is that some fella from MN makes oil pumps for AMC as well as some other trick stuff that doesn't have this problem. So I say buy that stuff from him and not worry about it but never force any close tolerance parts.
