Rear main Main oil bypass mods (post member pics here!)
Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Rear main Main oil bypass mods (post member pics here!)
    I was asked recently by a board member about this subject. This is a mod to supply additional oil volume to the rear main bearings and is usually only recommended for engines that will operate in the higher rpm range. I think MC can do a better job of describing the details of the mod than I can since it has been quite a while since I did this myself and he knows much more about AMC blocks than I do.
    I wanted to use the the stock metal valley pan gasket with my engine so I used brass fittings and a 3/8" steel line to make a low profile version that cleared the stock valley pan intake gasket. If I recall correctly I believe the 2 holes are drilled and tapped to 1/4"npt. The photos below show the details of my setup for anyone interested:
    editied by jeepsr4ever
    Jun 2004
    Fredericton, NB, Canada
    149
    On the second picture, there seems to be a line with a fittin on the other side of the block.. what is that?
    Feb 2003
    Santa Rosa, CA
    9
    Looks to me like it's something on the floor, not the engine. Like an intake manifold. Might just be me though.
    1974 Jeep J10- 401, T18, D20/ Dana 60&70 locked running on 39.5 TSL's
    Thank you from BT Gear Head
    Nov 2003
    249
    Fill tube and water neck on an intake laying on the floor.
    In America, there is no natural, moral, or legal right, to obligate another person or persons, to your dept or desires.
    Aug 2004
    Canada
    47
    I just pulled a block out of a 81 Wagoneer and the PO had done this mod to the engine. What would be the problem with it being in a DD as well as a off-road machine?
    You can run a daily driver with this mod
    Aug 2004
    Canada
    47
    Here are some more pics.
    Jan 2003
    1,437
    and more pic
    Oct 2004
    106
    This is with the extra oiling for the indy race heads that need to oil through the rocker shafts
    The oil line on the back is reading the oil pressure at the back of the block.
    Jul 2005
    S.W. WA
    692
    That shore is purty, looks mighty spendy too
    Quote Originally Posted by radamx
    1969 Rebel 401 TH400
    1978 J10 401, QT
    1978 Wag 401 QT
    1973 Javelin AMX in pieces.
