Will I have an issue with running stock springs, and a set of Thorley Tri-Y headers?
If I will have problems, what should or can I do to correct this?
Thanks in advance,
Mike
Thanks in advance,
Mike
Out to prove that AMC is still one of the best around!
In the fullsize waggy you should have no problems from what i can gather! If any you might need to clearance the tubes with a socket and some heat! Go for it the extra power will be nice!
cj7 360 roller motor 291c heads np435 dana300 4-1 plus northwest fab 2.72 black box, currie hi pinion 9 inch front and currie rock jock dana60 rear,38 inch tsls custom shackle reversal and a little bit of rust lol
On a Waggy, you should be A-OK. Plenty of room between the frame rails. Springs shouldn't be a problem, either. CJ's have problems clearancing with auto's due to the narrow frame width, but thats about it.
Jack
