water leaks
Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: water leaks
    water leaks
    Got an '80 Cherokee Golden Eagle, 360 and 4-sp. Looking to get some ideas on where to look for a neusance water leak. When driven in rain, water leaks into the passenger side foot-well, comes down through the heater vent. I'm guessing a weep hole in the cowl area, but it really doesn't leak when it just sits while it rains. We thought it was in the wheel well, and tries sealing it with undercoateing and roofing tar, but didn't work. I heard this is a common thing with these trucks. Any one else?
    "Balls!" says the Queen, "If I had them, I'd be King!"
    sheesh i am thinking right behind the heater box or windsheild seal...tigger might have a few ideaas on this one
    Dec 2003
    Hardin, MT
    2
    I would check the windshield seal or a radio antenna lead hole in the bottlm of the cowl air box.
    Dec 2003
    Gilmer, Texas
    29
    I had a problem with the windshield seal a while back. That's where I'd check. Mine was easy though. It was top center.
    71 Jeepster Commando
    Re: water leaks
    Quote Originally Posted by engine
    Have you pressure washed the engine compartment? Did it leak then? If so there are a variety of places on the P-side under or around the battery tray - the computer harness, fan motor and the heater drain, bolts, etc.
    If not pressure wash the windshield area for a few minutes. If you dont see any water, fold the windshield down and see if you've had encroachment past the rubber. This has been where mine have leaked in the past - air pressure pushes the water UNDER the rubber seal. If so you can get a new windshield seal OR I have used some 1/2 wide 1/4" thick door seal to stop the water from coming under the seal, it compresses nicely whan you put the winshield back up
    Another area is the front door seal???
    Let us know what you find out.
    I haven't pressure washed the engine compartment. I don't think this Jeep has a computer. Do you mean the main wire harness? When you say fold the wind shield down, you mean like the CJ7? this is a full size cherokee, the windshield doesn't fold down or anything. We sealed the windshield over, though. I don't think it's from there. \
    Right now it's too frickin cold to do anything . I can't even spend 5 minutes in the garage without freezin' my butt off. I'm gonna have to wait till spring.
    OOps Missed the Cherokee part before, I was thinking Golden Eagle Jeep Never had a problem with my Cherokees leaking Might still be something in the engine compartment though since it only happens when your rolling and not sitting (that is right - - right?)?
    And roger on the cold - my shop lost the heater a few days (weeks?) ago and it's buried under snow and sleet right now too!.
    The Cherokee is a Golden Eagle.
    Engine, this was the Golden Eagle I was thinking of... did you ever find the leak?
    Sep 2003
    Oak Harbor, WA 98277
    634
    Windshield seal, heater... etc all that was mentioned and also check the pass door seal, it could be running down and puddling in the floor if you aren't seeing a solid dripping from a certain area.
    The pressure washer idea is a good one have someone spray while you look.
